PJMARKOW's Avatar
Engine Finished
Finally finished my engine & it's in the car & running. Only oil leaks were from behind the turbo oil scavanger pump (cam shaft seal wasn't seated properly) and from around the oil pressure switch where the oil line for the turbo oil feed comes from. Both easy to fix. I just have to tweak the fuel and ignition maps to get it to idle and run properly so that I can run it in. It was running fine before the rebuild, but I've added GHL headers, 964 cams, Kokeln intercooler and K27 turbo, so now it won't idle.
PaulM
1977 930
1993 Nissan GT-IR
2000 Subaru WRX
Old 11-19-2004, 11:56 PM
konish's Avatar
Paul,
Nice work!
R/
Dustin
Old 11-20-2004, 08:45 AM
magic930's Avatar
Cool... which EFI system did you use?
Old 11-20-2004, 09:10 AM
rs911t's Avatar
Nice. Did you modify the stock blocks for the new injectors?
Greg
Old 11-20-2004, 01:21 PM
PJMARKOW's Avatar
I'am using an EFI kit supplied by PEM here in Australia. They modified the standard blocks to accept the injectors. The system uses a EMS Stinger ECU available here in Australia for $995 (Aussie dollars). The software allows you to create a log while you drive the car, so that I can see what O2 reading I'am running and make adjustments after each short drive. Beats trying to drive and see what the readings are at the same time.
Cheers
PaulM
1977 930
1993 Nissan GT-IR
2000 Subaru WRX
Old 11-20-2004, 01:48 PM
350HP930's Avatar
Congradulations.
I have similar plans for my own 930 with the exception of a larger intercooler and megasquirt ECU.
Old 11-20-2004, 02:40 PM
89turbocabmike's Avatar
Congrats Paul! Any closer pics of the injector block/ fuel rail set-up?
Old 11-21-2004, 01:27 AM
Bird. It's the word...
Fishcop's Avatar
Nice work! Mille Miglia exhaust?
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 11-21-2004, 05:02 PM
PJMARKOW's Avatar
Yep, and GHL headers as well.
The thing that pissed me off were the pipes that connect to the front of the heater boxes. The right one fit perfectly, but the left one came up right where the left axle is. These are supposed to be for a 930.
PaulM
1977 930
1993 Nissan GT-IR
2000 Subaru WRX
Old 11-22-2004, 01:50 AM
Just attach the heat exchangers using flexible hose. I didn't use their pipes at all.
Brian
Brian Keith Smith
Old 11-22-2004, 03:27 AM
BoxsterGT's Avatar
Can you tell me how to reach PEM?
Their web site does not seem to work.
An address or phone nr would help.
Thanks.
Old 11-25-2004, 05:11 AM
PJMARKOW's Avatar
I know that PEM are relocating to Queensland (Australia) from Sydney at the moment. I can give you Andrew Howards mobile number, it's 0411 249 574.
Cheers
PaulM
1977 930
1993 Nissan GT-IR
2000 Subaru WRX
Old 11-26-2004, 12:07 AM
Paul,
Who are EMS stinger? I have not heard of them! Let me know if you need an extra pair of hands when you put the engine back in.
Cheers
Mark.........
Old 11-29-2004, 02:31 AM
PJMARKOW's Avatar
The EMS Stinger is the CPU that is controlling the fuel and ignition on my engine. Locally made here in Australia by EMS (www.enginemanagementsystem.com). The engine is already in the car. Thanks for the offer though.
PaulM
1977 930
1993 Nissan GT-IR
2000 Subaru WRX
Old 11-30-2004, 02:15 AM
