Engine Finished, In car and runs!
This is a stock rebuild of a 2.4E MFI, Had 1 small problem getting it to run, CDI had issues and points (needed cleaning), Also I must have been asleep putting the left cam oil line on as it wasn't tightend but other than that went smoothly, Engine runs and idles and I have only set the timing
http://forums.pelicanparts.com/uploa...1101090851.jpg This is the Car after a 10+ year resto almost ready for the PCNZ concours on 5th December http://forums.pelicanparts.com/uploa...1101090904.jpg Thanks to all that have contributed advice (and in some special cases parts) Neven |
Neven,
Magnificent job! I'm sure you'll get many years of enjoyment out of it. -Andy |
Great work... is that Pastel Blue?
John
It looks a bit darker in real life the colour is 'Icing Blue' Neven |
Engine looks great!... I see a hose connected to your exhaust. Did you run it on that stand?
I was wondering if someone would ask that, No it is a budget flow bench for setting up the throttle bodies (which I'd rebuilt), When you put a cylinder at TDC with valve overlap only that cylinder has a path from the exhaust thru to the intake (both valves open), The hose is connected to a vaccum cleaner, I then used a synchrometer to measure airflow for each cylinder at idle and part throttle settings, you can do it for more than a minute at a time for the vacuum cleaner overheats!
It worked well though when I first ran the engine I was only slighlt out between the left and right backs Neven |
Clever...
The car and the motor look fantastic.
Now about that ride height... Paris Drakar? |
Neven, fantastic job on your engine and your E looks great! |
Another longhood set for many years of enjoyment. Glad to hear that its running smoothly. I like the thought on the flow test.
Bobby
Well spotted, The ride height is high at the back, needs to come down about 10mm, Its not Paris/Dakar settings! Maybe you guys with flares and lowered suspensions have forgotten what a std 911 looks like :-) Neven |
Neven,
That "budget flow bench" is very clever. As far as ride height, I hear that standard height is making a comeback, probably a result of all the SUVs on the roads here in the states. Gary |
Neven,
Actually I haven't forgotten, I just couldn't resist a chance to show what Porsche nerds Jim and I are. :) P.S. The car really is inspirational. |
Bobby
The car is off to the suspension place today to be lowered, you didn't comment on the 1 degree +ve camber at the rear (which we hope to get rid of by lowering), I know its offtopic but I thought you might appreciate this photo http://forums.pelicanparts.com/uploa...1101410594.jpg |
oh my god. Neven you are one HARDCORE MUTHAHUBBARD! you have just invented a new form of restoration. its called EXTREME REBUILDING!
Andy. |
Andy
You'll appreciate that the car is ex UK (That darn salt gets everywhere), came to NZ about '85, I'll be putting up a website with more photos so stay tuned! |
yeah, bloody england with its bloody rot. oh well.
Andy |
Wow that's insane.
How many times did you go to lift the pan off only to find yet another spot weld you missed? I just wish I could retire so I could devote myself to a restoration of that degree. What fun. |
| All times are GMT -8. The time now is 05:42 AM. |
