What's the hottest 3.2 cam you would use?
I'm just about to take the engine out to properly recam my 3.2 as I made the mistake in my top end rebuild of putting my stock cams back in after I went to Mahle "Euro" 10.3-1 p/c, Ollies full race heads (every option on the menu 'cept porting), ARP rod bolts & head studs.
The engine runs great except that with the stock cams it seems to start running out of breath around 5500 rpm. It's a 80% track car.... So here's the question.....964 cams are too mellow in my opinion, the webcam 20/21 grind seems to be a little better with similar duration and a little better power due to increased lift compared to the 964 grind. But the "3.8 Super Cup" Grind from DRC is a little hotter- with a tad more lift and a tighter lobe center than the 20/21 grind and I'm thinking I would like to go with that..... Anyone out there have experience with this cam? I've spoken with JD (camgrinder) via emails and he's done a great job of helping a driver (as in not a 911 mechanic...) like me out so I now understand the basic's of this cam stuff.... Any input is most welcome, I will have the shop order up my cams next week.... Many thanks in advance....:) |
Just for the heck of it, have you tried retarding your cam timing for a little more top end?
-Chris |
I believe your piston choice will severely limit your cam choice. Assuming you have Motronic and enough valve clearance the Super-Cup grind is about at the most aggressive and is a huge improvement over the stock profile. IMO.
I was very concerned about piston to valve clearance on this cam as well.....several emails b'tween cam grinder & myself as well as pm's to fellow pelicanites Rdane and carrera 3.5L. Concerning the piston to valve clearance on this particular cam, which was on my mind constantly, I decided to chk out Rennlist and found a thread.... http://forums.rennlist.com/rennforums/showthread.php?t=169098 Look for Camgrinders comments half way down regarding the factory 3.8 Super Cup Grind .... Camgrinder quote fm rennlist: "Most people think adding total valve lift will put the valve closer to the piston. But full valve lift occours 112 degrees past top dead center on this cam. Meaning the piston is more than halfway down the cylinder bore at full lift. The parameters that have the most effect on valve to piston clearance are, Duration ( The time the valve spends open) and Lobe centers ( the centerline of the lobe in degrees from top dead center ) The rule of thumb is: More duration or tighter lobe centers = the valve/piston will have less clearance Less duration or wider lobe centers = the valve/piston will have more clearance 98 degrees would be a tight lobe center and 112 is a wide lobe center. __________________ John Dougherty http://www.drcamshafts.com (John I hope you don't mind me using this... ) The above explanation REALLY cleared things up for me - Thx JD. Based on this info I am alot more comfortable with it..... My mechanic will check every thing very closely....(my wife is the office mgr and signs his pychk!!) If I have to go with a more mellow cam I will...but based on my engines parameters this is the one JD recommends. Any one out there put it in a 3.2...??? or am I going to be the first? :eek: :D |
I'm doing an upgrade rebuild on my '85 3.2 -I will go to 3.4 P/C's and use the super-cup grind because IMO it has good lift and duration for a performance street engine plus the lobe centerline is still conservative enough to run with Motronic. In other words it is the most aggressive grind that you could run and still retain stock-like driveabilty.
I'll use JE's (pistons) because they allow me to custom order the dome shape, compressio ratio I want. From what I've learned here and other credible P-car engine guys is that the Mahles do no have enough valve relief and you can't modify them any further. I recently spoke with John; DrCamshafts about this build and he was very informative and helpfull. My main concern was maintaining good cylinder pressure with 9:8-1 with this cam profile. His experience was that it would work great and result in about 175-180psi for my combo. Exactly what I wanted. I'll buy my cam and springs from him. |
Mahles do no have enough valve relief for this cam? or for other more aggressive grinds? Like John points out in the quote above: ".... full valve lift occours 112 degrees past top dead center on this cam. Meaning the piston is more than halfway down the cylinder bore at full lift." based on that I am understanding that if this is the case, with the piston halfway back down the cylinder at full valve lift there should be no clearance issues. Or am I missing something here? |
One things for sure nobody will know until you bolt it in (with the proper set up) and see what the valve to piston relationship is. Several experienced builders tell that once you pass the 964 grind (Lift and duration) things get close.
If your short block is all good, get the heads set up and see just how much clearance you have. |
If you use the Mahle's designed for carbs/mfi (which I did), you will have much more clearance and it won't even be an issue. I used Web 20/21's and Web states that the piston to valve clearance should be at least .050" intake and .080" exhaust. No problem at all for my pistons, as this piston set was designed for much more aggressive cam profiles. I just have to retain Motronic to pass smog and thus need a "civilized" cam grind.:( Good call on the JE's providing you the CR you want, don't even get me started with the Mahle's on that one. I think the JE's are made with the carb/mfi style dome as well, so you might consider twin-plugging in addition, especially if subjected to 91 octane like I am.:( Johnny, you are in SoCal but I think that you mentioned that yours is more a track car so I assume that you are using better gas? Both of you guys keep us informed with the latest developments, it is always nice to watch the build process and see what other people are doing. Ralph |
wow...!! always nice to hear your .02 Ralph....very much appreciated:)
And yes you are right Ralph, I normally run higher octane than the std pump piss we have...specifically a blend of 50/50 91 & 100 octane for an average octane of 95.5.....and truth be known with the standard OEM 3.2 gasket set from SSF that was used in my top end rebuild I now feel I would be lucky to actually have the advertised cr of 10.3-1....especially after following Ralph's CR ordeal on his beautiful hot rod motor rebuild....If I had to throw down a few $$$ in a bet I'd probably say ...and a pure guess it is....would be I'm in the neighborhood of 9.8-1...??? I will have that chkd in the coming weeks tho.... My Mechanic has built alot of 3.0 & 3.2 motors over the years and I will go over the cam issues with him prior to the cam install......I will not run the motor until I am DARN sure there is safe clearance with the piston/valves. to be continued....... |
Johnny: 3 questions for you:
Are you stock (not twin-plugged) Motronic? Did you ever run your motor on straight pump gas? Other than running out of breath at high R's, how much different feel did you get from the high comp pistons? |
I am puzzled at all the talk. If you do not MEASURE the valve to piston clearence, you shouldn't put it back togather, let alone run it.
Yeah, what he said!
I would suggest obtaining a program called Dyno 2003. Its an engine simulator program thats quite accurate, within a couple of percent, maybe better if you are careful and feed it very correct info. I don't know if our host sells it but if he dosen't he might want to check it out.
With this program you can plug in what you have and you should see a result thats pretty much what you have now. If not go back and measure some things in your engine until you get good results. Things to measure: cam timing, valve lift vs crankshaft degrees, compression ratio of every cylinder, actual stroke of Each throw, valve size, intake runner type and size, injector size,or carb size. These are all things you should already have done if you rebuilt the engine, if not you will need them for any track car. For the program you can use estimates for some or default values for a start. Play with cam timing and see where if dies, should be same as real engine. Then start modifying program (not engine) and see what you can do. Once you think you have it check with everyone who has already done one to see if they concur or if there might be a problem thats been over looked. Its real cheep compared to real engine parts and you can predict what you will end with. I would go for a cam that peakes at about 6800 and red line it at 7200. Thats a qualified 6800 meaning you do whatever else is necessary to make it work right. |
Of course you should measure, I don't think any of this talk leads to the assumption of just bolting it together without checking. I measured piston to valve clearance on my motor and had plenty of clearance, helped in part by using the carb/mfi piston that has the deep valve relief cut-outs. These were designed for much more radical profiles then the docile 20/21's I'm using. You should always measure, whether using the CIS/Motronic dome or carb/mfi piston dome. Never assume anything!:) Hopefully his former mechanic who performed the top-end rebuild for Johnny has a "build sheet" with all the pertinent information but if not he should make sure his new mechanic can provide him the info. Ralph |
As an initial "point of reference' his comments are encouraging, and are leading me to pursue this path. However as all here are quite aware the proper checks and measurements must be taken. As a point of interest, during my rebuild, I had the opportunity to hold and very closely compare visually both one of my original 9.3 USA DME pistons and one of my new Euro 10.3 DME pistons. I honestly held both in each of my hands for at least 30 minutes...staring and comparing from every angle and honestly - for the first 20 minutes I could not tell the difference. I actually began to get concerned (read: panic) that I was not sold what I had ordered. Then I realized that the difference was in the height of the tapered shoulders that wrap around the top. The difference was in that the taper of the dome shoulders as I call them, that wrap around the circumference of the top have a more gradual angle or slope down towards the center of the piston top where it is flat. The max dome height was virtually the same from my measurements. Again, it was very, very hard to distinguish any difference between the two by my eye. and I was not in a rush or hurried and had the rest of the day to stare at these 2 pistons and believe me, I took my time to be sure. There is a difference...but not a very big one at all...marginal at best in my opinion. But rest assured, I will have the p to v clearance measured on each cyl. Ralph, I am still using my same mechanic who built my motor originally. I do have a build sheet in my file on the top end rebuild, I will go to the shop and check it out. Ed - I have not run normal premium (91 octane) pump gas since my rebuild. It is not a daily driver, used 80% for track events. As I mentioned in an ealier post I run a minimum 50/50 blend of 100 & 91 octane for a total octane of 95.5 yes I am single plugged DME W. a chip. the new p/c give a bit better mid range torque and push up to that mid 5k range where the push begins to taper off ...just like every other stock cammed 3.2 I suppose. |
Johnny,
If its a street engine, the builder may not have measured valve to piston clearence because its so large to begin with. On a track enging the clearence is usually half a hare from total destruction all the time. |
I too doubt the valve to piston clearance was measured. specifically because of the stock cams that were being re-installed. But my wife, who is the office mgr (and has worked with 911's for 22 yrs now...) sez she has all the notes the mechanic made during the rebuild.....I guess I'll find out.
But with the new cams, that will be a different story. I am going to have all cyl clayed to measure the p to v clearance. I've learned alot so far... the education continues.....:) |
Couple of things:
- See my diagram of piston / valve clearance in the Engine Rebuild Book for a clear understanding of when the conflict typically arrises. It is not what most people think (at TDC). - The Motronic system here is your biggest limiting factor. To run really aggressive cams, you need individual throttle boddies (like on carbs or MFI). See Chapter 4 of the book for more on this and fuel reversion effects... -Wayne |
This threas is exactly what I have been looking for. I am in the middle of modifying my euro spec 3.2 to a 3.5 using Mahle pistons and barrels. It will have a Mtec M48 pro and throttle bodies. The primary use will be as a fast road car with occasional track day use.
Can anyone advise me of the most aggressive grind I can use while still providing street reliability and smooth idle? Is it the 964 super cup or an early 'S' grind. BTW, does anyone have the profile data for these CAM's? Many thanks Pete |
The most aggressive cam that you can run would be the 993SS cams.
They do make the idle just ever so "cammy", if you know what I mean. That's because they were designed to work with a mass-flow sensor, and not a flapper box airflow meter. But they sure do make great power, if you don't mind slightly diminshed idle quality, and possibly the occasional fall off idle. |
Sorry for the intrusion, but I too am performing the identical modification...this is exactly the question I too was going to post. Thank you all ahead of time. I'm enjoying reading everyone's feedback, its very helpful. Oh, I too could not easily and still can not see the differences between U.S.A. and Euro high compression C/P's. I posted a topic on this a few weeks ago.
Best Regards, Alex |
that sounds great. Do you know the cam specifications for the 993SS profile? Also, I dont suppose you know the standard 3.2 cam spec for a comparison. In you opinion is it better to buy original 993SS cams (assuming they would fit a 3.2) or to buy a billet and have it reground? Cheers Pete |
It's probably be less expensive if you have your cams reground. Check with Webcam as I believe this is one of their cams and they would have all the specs.
Is the 993SS cam the same as 3.8 super cup?
Noah, I think if your map sensor is between your throttle body and the plenum (not in a place where one cylinder is going to affect the local pressure a whole bunch) you should be OK. I agree that all other major components are similar. I would talk to camgrinder, he has specs for a bunch of this information, and probably knows the details. since you already have 964 cams, though, I don't think there would be a big power increase if the 993SS is the same as a 3.8 super cup. the specs aren't all that different. The lifts are bigger but the durations are pretty similar. |
I believe the 993SS cam is very similar to the 3.8 Supercup cam.
Noah, yes you can run even the Mod-S cam in your car with that induction. (It won't clear those hunch-back CIS pistons though, so stick with the 993SS) But you should put a restrictor inline to the map sensor. A 1.25 carb jet works well for this. BTW, this is Tyson at Jeremy's computer. |
I'm sorry to hijack, too, but when looking at camgrinder's chart, it seems that SC cams can be reground to 993SS cams. Is this true? Will 993 cams work in a 3.0 with CIS? Just wondering...SmileWavy
I believe he's labeled it "Super-S"
btw, that website is his business. Tyson, are people really running a Mod S with a 3.2 intake for example? I would have thought the lobe centerlines/duration would make for rotten low-end response, lots of waves bouncing around in the shared manifold. |
The carrera manifold has very large common chambers which should do a good job at keeping pressure waves and inversions from one cylinder from interfering with the others.
My DC40 is like the Mod-S cam. I like to move the lobe centers when used in larger displacement engines. 102 is good for a 2.2 or 2.4 litre and 108 or wider for 3.0 and larger.
I made a few 108 and 112 lobe center versions of the Mod-S when I was at Elgins. If the person was to recommend the Mod-S cam I would ask about the lobe centers. The Super-S cam is a custom job I did for someone who wanted the S type powerband with a new style higher lift profile. I have not tried to grind an SC cam with the Super Cup profile. It may work. I have put it on 964 cams easily by using the 964 lobe center of 113. |
John,
Why would you open up the lobe centers on larger engines? Is this using the assumption that the factory fuel injection is being retained? |
Matt,
Wider lobe centers are mandatory with factory fuel injection. I think if you search this board you will find my reasons for opening up the lobe centers on larger engines. If not I can give you some details. Porsche has also done this, 906= 95 degree lobe centers, 3.0 RSR= 101 lobe centers and the 3.8 RSR has 109 lobe centers. Of course there are many variables in this comparison. |
John, do you have customers runing 108 or 112 mod-S cams with plenum manifolds (single throttle body) and good all-around response?
Thanks in advance! edit to clarify: obviously you wouldn't just slap these into a stock SC engine, but if other compnents were matched... I'm ignoring the effects of the CIS flapper, if any. I'm thinking of an engine like a carrera 3.2 manifold or one like noah's, cis->efi |
Andy,
With a programable EFI system the Mod-S 112 (DC40-112) cams will work. It will need increased a compression to ratio. (10.5-1+) My normal choice would be the EVO cam. But if the customer needs more top end power (7500 rpms or so) and was capable of tuning the system, I would choose this profile. |
wow, neat. Thanks for the info, John.
But Noah is using a speed-density system with a MAP sensor. It may work with the Mod-S cam, if he uses a restrictor inline to the MAP sensor. We used Mod-S cams in a 3.2 with the flapper box for a race-only car, and actually got it to idle decently, and have good throttle-response and driveability, but it would fall off idle and stall every time you blipped the throttle. We simply raised the idle to 1400 rpm with Steve Wong doing the chip re-programming for us. |
I believe tyson is just talking about a fitting with a smaller hole in it in the hose from your intake manifold to your MAP sensor. Plain old restrictor. I'm not sure what's available but you could just adapt down to a smaller barb fitting if you had to, it would accomplish the same thing. or you could just put some epoxy in a barb fitting and drill a small hole through it.
It might be best to take John's recommendation, though. Probably depends what Noah wants. |
I would interested in who has done a speed-density system on a 3.2. Does anyone make a kit? If so who does the software?
I'd convert the whole thing over to megasquirt, if it were me. Tune to your heart's content!
more info in this thread, which addresses a 6 throttle body setup, but the basic megasquirt would work equally well with a stock style manifold: http://forums.pelicanparts.com/showthread.php?s=&threadid=205837&highlight=megasq uirt |
I think it was a 110 or 112 lobe center. Standard early S is 97. Noah, the restrictor is simply a carburetor jet that you stuff into the vacuum hose going to the MAP sensor. I remember using a 1.25. |
| All times are GMT -8. The time now is 08:59 AM. |
