Standard/Standard?
When someone is refering to a crank, why do they say STD/STD? Why not just standard?
Paul |
STD/STD means standard size on the rod journals and standard size on the main journals.
I see. Thanks John.
Bearings are the same way. You can have bearings that have a larger outer shell (oversized) to compensate for worn bearing surfaces in a case. Or, bearings that have a larger inner shell, to compensate for worn jounals on a crank.
-Wayne |
| All times are GMT -8. The time now is 03:14 AM. |
