Question which flywheel seal???
I'm confused... my flywheel seal seems to be leaking - this is the one you can see after removing the flywheel looking at the outside of the engine.
Checking with the parts catalog, I discovered two part # per Perlican parts site:
99911342640 Crankshaft to Flywheel Seal
99911326440 Flywheel Seal
The parts catalog I have (Parts & Technical Reference Catalog by Porshce) and all the diagrams I have seen does not seem to show the Flywheel seal.
So, which one do I need? Why one has the correct part #?
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Old 12-02-2004, 08:17 AM
bump.... anyone?
Old 12-03-2004, 06:34 AM
Jubbie's Avatar
If I look at our host's catalog:
The 99911342640 is for the 78-89 Crank and the 99911326440 is for the 90-98 964/993 crank. I would think that for your 87 930 you would need the 99911342640 which is listed as K-113-426-40 by our host.
John F. Lewis
74' 911S Targa + 930/02
76' 914 - Eternal Type IV project FOR SALE
Old 12-04-2004, 08:37 AM
Thank you John... I must have been blind
Old 12-04-2004, 02:24 PM
Jubbie's Avatar
No problem, hope it fixes the leak.
John F. Lewis
Old 12-05-2004, 02:27 PM
