993TT P&C's in a 993 NA Motor?
Hi, just a quick question, would 993TT P&C's bolt right into a N/A 993 engine without any case or head mods?
This is for an aftermarket turbo conversion for a mate's 993 C2S :cool: If he can do that, then he'll shop around for second hand 993TT P&C's, or just slip in some lower compression JE Pistons in his existing cylinders. What about 3.8 Turbo P&C's? Are these a bolt-in item, or does one have to machine out the case and heads? |
Bump!
Never got an answer to this one. Does anyone know? I think both the 993TT and NA 993 have the same bore & stroke, so swapping P&C's should theoretically work?!? |
There are no 3.8 Turbo engines as far as I know. Only 3.8 engines I know about are rare RS models (without turbo, of course).
I believe 993TT pistons should be bolt-on to N/A 3.6 motor, but they are rare and still not stonger/lighter that custom made JE's, so It might be better upgrade path. |
993TT P/C's do not fit the N/A 993 heads without modifications.
There are major differences in how the TT cylinders join & seal to the heads. |
Hmmm, perhaps a set of 8.0:1 Forged JE's slipped into the existing cylinders would be a better option then?
That's the direction I am going in. Turbo pistons in 993NA cylinders.
Rick '78 930 |
| All times are GMT -8. The time now is 07:27 PM. |
