WydRyd's Avatar
993TT P&C's in a 993 NA Motor?
Hi, just a quick question, would 993TT P&C's bolt right into a N/A 993 engine without any case or head mods?
This is for an aftermarket turbo conversion for a mate's 993 C2S
If he can do that, then he'll shop around for second hand 993TT P&C's, or just slip in some lower compression JE Pistons in his existing cylinders.
What about 3.8 Turbo P&C's? Are these a bolt-in item, or does one have to machine out the case and heads?
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 11-30-2004, 08:58 PM
WydRyd's Avatar
Bump!
Never got an answer to this one. Does anyone know?
I think both the 993TT and NA 993 have the same bore & stroke, so swapping P&C's should theoretically work?!?
Merv
'89 911 Turbo Cab
Old 07-10-2005, 06:39 PM
beepbeep's Avatar
There are no 3.8 Turbo engines as far as I know. Only 3.8 engines I know about are rare RS models (without turbo, of course).
I believe 993TT pistons should be bolt-on to N/A 3.6 motor, but they are rare and still not stonger/lighter that custom made JE's, so It might be better upgrade path.
Thank you for your time,
Old 07-10-2005, 11:52 PM
993TT P/C's do not fit the N/A 993 heads without modifications.
There are major differences in how the TT cylinders join & seal to the heads.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 07-11-2005, 01:07 AM
WydRyd's Avatar
Hmmm, perhaps a set of 8.0:1 Forged JE's slipped into the existing cylinders would be a better option then?
Merv
'89 911 Turbo Cab
Old 07-11-2005, 06:12 AM
rick conrath's Avatar
That's the direction I am going in. Turbo pistons in 993NA cylinders.
Rick
'78 930
Old 07-12-2005, 01:46 PM
