sketchers356's Avatar
Early S Cams in 2.7 with Std S Pistons?
I thought that I heard somewhere that you cannot run the early S cams in a CIS 2.7S because of valve impact with the piston. Instead one would have to switch to RS pistons. Is this true?
I have been thinking about switching to EFI and this would be the next mod after doing such. If I could just pop a new cam it would give me extra incentive.
Alexander
'75 911S Targa
'86 951 SOLD
Old 12-01-2004, 04:22 PM
Yes, this is true. Aftermarket pistons are another option. Some will say the Mahles provide the longest service life.
Sherwood
Old 12-01-2004, 04:33 PM
Assuming that my pistons are in good condition can I simply swap out my pistons/piston rings?
Sounds pretty good otherwise!!
Also, I am interested in switching the cams because I like driving higher in the RPM band when I am in a sporty mood. Is there a cam that is streetable but even more 'hot' than the early S?
Thanks for the help.
Alexander
'75 911S Targa
'86 951 SOLD
Old 12-03-2004, 06:09 AM
Author of "101 Projects"
Wayne 962's Avatar
I'll assume that you meant:
Assuming that my *cylinders* are in good condition can I simply swap out my pistons/piston rings?[/QUOTE]
Yes, you can, but most of the 2.7 used cylinders turn out to be junk...
-Wayne
Old 12-03-2004, 11:39 AM
KobaltBlau's Avatar
But you can have them bored and replated and get JE pistons to match. This ain't free, but it's usually cheaper then a Mahle set. Alternatively you can find somebody else's used Nikasils if yours aren't Nikasil or aren't in good condition.
Andy
Old 12-03-2004, 03:47 PM
camgrinder's Avatar
If your switching to EFI the S cam's 98 degree lobe centers will be too tight. I would try a wider lobe center cam with less duration and similar, or more valve lift.
It really depends on how much valve overlap the EFI will take.
John Dougherty
Dougherty Racing Cams
Old 12-04-2004, 01:02 PM
dweymer's Avatar
would a 996 cam work? benifits? thought I remember reading that it would somewhere.
Donnie
Currently Porsche-less.....
Old 12-06-2004, 06:35 AM
Gon fix it with me hammer
svandamme's Avatar
a 996 cam has 4 bearings
early cams use 3
so the cam housing will be a problem ( and beeing a watercooled engine , it's not simply a bolt on swap for the housing either )
besides that, 996 = variocam...
Stijn Vandamme
BIMDIESELBMW116D2019
Old 12-06-2004, 08:38 AM
camgrinder's Avatar
I thought the 996 was a 4 cam engine?
John Dougherty
Old 12-06-2004, 08:59 AM
Old Member
Alexander
I have a pair of freshly ground 2.7 CIS cams with a 3.0SC CIS grind.
These cams are in excellent condition, still in the sealed box from the shop and ready to install.
These cams have the nut style front snout and fit early Porsche 911 2.7 litre CIS type engines. These cams should provide an easy 15 to 25 additional horsepower to a stock engine and still allow your car to pass emission testing.
The Intake duration @ 1mm is 236 degrees valve lift is .450".
The Exhaust duration @ 1mm is 224 degrees valve lift is .395"
Set up at 1.4-1.7 mm
A very popular upgrade for the 911 2.7 S engine with CIS injection.
The casting numbers are 911 105 143 0R left side and 911 105 144 0R right side.
Price is $290 but all offers and trades are considered.
Clifton Brown
https://www.mancalamarketing.com
Old 12-06-2004, 09:08 AM
dweymer's Avatar
sorry all not 996; 964 cam, too many numbers to remember.
Donnie
Old 12-06-2004, 12:43 PM
svandamme's Avatar
just checked PET, your're right ...
so there's another reason why not
Stijn Vandamme
Old 12-08-2004, 04:43 AM
svandamme's Avatar
964 is also a 4 bearing cam ... so you would also need the cam housing ( i think it should be just a bolt on replacement , but not speaking from experience , maybe somebody else can comment on that)
Stijn Vandamme
Old 12-08-2004, 04:44 AM
dweymer's Avatar
I thought it was in Waynes book, no details on it though; I was hoping he would confirm what was needed.
Donnie
Old 12-08-2004, 07:22 AM
