Camshaft binding after tourqing head studs
Camshaft has a slight drag to it. I've re-done the head stud tightening sequence 3 times with the same results.
Suggestions please -doug |
then one of the heads is thicker or thinner than the rest, you could have a cylinder with a different height group, or the cylinder bases on the case are worn to different heights. year of engine/car?
I had the same issue last winter - replaced the camshaft (with a new one) and after installation, the right side has a serious drag. Measured the runouts on both cams and they are very small.
I finally "fixed" it by changing the torque pattern.
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Head stud pattern or cam tower pattern?
This is a 3.6 liter that is a new rebuild. I had to partially take down one side after assembly to replace an improper set of rings and I'm in the process of putting it back together. When I first assembled the engine the camshafts did turn freely. -doug |
In my case, both...
a 3.6 shouldn't have the issues i described, especially one that's using the same parts it came with. uneven setting of loctite 574 between heads and cam tower could be an issue. were the heads removed from the cam tower to correct the ring problem, or were they left on?
Two of the heads were left on the cylinders.
Perhaps I should just start over with the cam tower install? By the way, I really appreciate the advice. -doug |
yeah, i'd re-do that side.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 12-09-2004 at 04:27 PM.. |
Author of "101 Projects"
Clean everythiing real well too, prior to reassembly...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Yes, that's what I did as well - Removed the CAM tower from the head, clean everything really well & re-assembly. During my re-assembly, I did use different torque pattern than before. Rather than torque to 75% then all the way per Wayne's book, I also did many smaller increments with the CAM inserted in the tower.
