Virginia Rocks!
VaSteve's Avatar
Porsche Crest Is this a Healthy SC Engine?
The local NoVa gang got to me yesterday and now I have my engine free of the car in the garage.
I pulled the engine to address some leaks and while it was out inspect some other things. I planned to adjust the valves and wanted to check the head studs. I didn't find any loose barrell nuts, I put a 10mm allen in each one and gave a real light twist - all seemed secure - is that all there is to it?
Can someone please advise from these photos if everything looks ok. I'm a little concerned over cylender #3. There looks to be a lot of burned up oil around it I didn't see around the other cylenders.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 12-12-2004, 04:06 PM
Virginia Rocks!
VaSteve's Avatar
#3
This is the cylender I'm talking about. #3:
#1 was a little grimy on the outside side...
Old 12-12-2004, 04:08 PM
blue82coupe's Avatar
Looks like rocker shafts leaking and or cam tower to head leakage. Could also be the valve cover gaskets. Dan
I have plenty of lead for my pencil... just not enough paper to write on..
82SC with 95 993 engine
2004 Ford Powerstroke
Old 12-12-2004, 04:29 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
NoNo scrapit or ship it to me....
Seriously, that is impossible to tell from a couple of pictures alone. The good news is that you have no boken head studs. What you see is the result of an oil leak like others said. It could be as simple as warped valve covers (sand them down) or leaky rocker shafts (tighen them a little) or more involved such as chain housing to cam tower gasket leak.
Another concern could be worn valve guides. Smoke on decel is a good indication here. A compression/leakdown ususally gives you some more insight. How many miles on the engine? Have fun,
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 12-13-2004, 05:36 PM
Virginia Rocks!
VaSteve's Avatar
105 on the engine. The gunk around #3 may have crept in past the tin because I had a nice leak coming from the breather/termostat/pressure switch (yes, that leak ).
No smoke on decel.
Old 12-13-2004, 05:44 PM
ischmitz's Avatar
The breather hose leak is very very comon. An engine might look squeaky clean. Once you remove the shroud you are in for a surprise.
For all I know this leak killed my 3.6 in its early life. The oil was baked on in a half inch thick layer preventing proper cooling. That resulted in overheating/warped heads. The outcome was a costly rebuild.
Yours looks not too bad. Good thing you found your leak early.
Cheers,
Ingo
Old 12-13-2004, 05:56 PM
Gordo2's Avatar
Those Crazy NoVa Guys are Just Itching to Pull Motors
Obviously they didn't let you know you could adjust the valves with the engine in the car
Watch out for the "while it's out" bug.
Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 12-13-2004, 06:08 PM
OldTee's Avatar
Study that crowd closely! Have you counted your engine parts lately? They look like they could try out for a reality edition of Oceans 13!!!!!
gang!
Old Tee
all 911s sold
Old 12-15-2004, 02:29 PM
Bandwidth AbUser
Jim Richards's Avatar
We NEVER do unnecessary surgery in NoVA.
Jim R.
Old 12-15-2004, 07:53 PM
Senior Member
Superman's Avatar
Replace the thermostat o-ring, the oil pressure switch, perhaps the breather cover gasket, some rubber parts (intake runner sleeves, etc), button her up and drive the piss out of her.
Mocha 1978 911SC. "Coco"
Old 12-16-2004, 12:30 PM
Author of "101 Projects"
Wayne 962's Avatar
There's an article on fixing all of these leaky spots in 101 Projects...
-Wayne
Old 12-16-2004, 11:43 PM
Virginia Rocks!
VaSteve's Avatar
-Wayne
Got it...and the engine book.
Supe, I'll be back to driving her like Gramma in no time.
Old 12-17-2004, 09:22 AM
Now in 993 land ...
aigel's Avatar
My bet is either rocker shaft or cam end plate o-ring. Just do them both. Good time to upgrade to better cams!
George
81 SC (sold)
Old 12-17-2004, 10:37 PM
Super Moderator
cstreit's Avatar
Hmmm... I see plenty of loose nuts in that first picture
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 12-18-2004, 09:16 AM
Virginia Rocks!
VaSteve's Avatar
Well, you have met the Dorki crowd!
Old 12-18-2004, 09:31 AM
