Virginia Rocks!
The local NoVa gang got to me yesterday and now I have my engine free of the car in the garage.
![]() I pulled the engine to address some leaks and while it was out inspect some other things. I planned to adjust the valves and wanted to check the head studs. I didn't find any loose barrell nuts, I put a 10mm allen in each one and gave a real light twist - all seemed secure - is that all there is to it? Can someone please advise from these photos if everything looks ok. I'm a little concerned over cylender #3. There looks to be a lot of burned up oil around it I didn't see around the other cylenders.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na Guards Red is for the Unoriginal
Virginia Rocks!
#3
This is the cylender I'm talking about. #3:
#1 was a little grimy on the outside side...
Looks like rocker shafts leaking and or cam tower to head leakage. Could also be the valve cover gaskets. Dan
I have plenty of lead for my pencil... just not enough paper to write on.. 82SC with 95 993 engine 2004 Ford Powerstroke |
Author of "101 Projects"
Looks pretty good to me. I have seen that grime near all cylinders before...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
NoNo scrapit or ship it to me....
Seriously, that is impossible to tell from a couple of pictures alone. The good news is that you have no boken head studs. What you see is the result of an oil leak like others said. It could be as simple as warped valve covers (sand them down) or leaky rocker shafts (tighen them a little) or more involved such as chain housing to cam tower gasket leak. Another concern could be worn valve guides. Smoke on decel is a good indication here. A compression/leakdown ususally gives you some more insight. How many miles on the engine? Have fun, Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
Virginia Rocks!
105 on the engine. The gunk around #3 may have crept in past the tin because I had a nice leak coming from the breather/termostat/pressure switch (yes, that leak
). No smoke on decel.
The breather hose leak is very very comon. An engine might look squeaky clean. Once you remove the shroud you are in for a surprise.
For all I know this leak killed my 3.6 in its early life. The oil was baked on in a half inch thick layer preventing proper cooling. That resulted in overheating/warped heads. The outcome was a costly rebuild. Yours looks not too bad. Good thing you found your leak early. Cheers, Ingo
Those Crazy NoVa Guys are Just Itching to Pull Motors
Obviously they didn't let you know you could adjust the valves with the engine in the car
Watch out for the "while it's out" bug. Gordo
Don "Gordo" Gordon '83 911SC Targa |
Study that crowd closely! Have you counted your engine parts lately? They look like they could try out for a reality edition of Oceans 13!!!!!
gang!
Old Tee all 911s sold |
Bandwidth AbUser
We NEVER do unnecessary surgery in NoVA.
Jim R. |
Senior Member
Replace the thermostat o-ring, the oil pressure switch, perhaps the breather cover gasket, some rubber parts (intake runner sleeves, etc), button her up and drive the piss out of her.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
-Wayne
Virginia Rocks!
![]() Supe, I'll be back to driving her like Gramma in no time.
Now in 993 land ...
My bet is either rocker shaft or cam end plate o-ring. Just do them both. Good time to upgrade to better cams!
![]() George |
Super Moderator
Hmmm... I see plenty of loose nuts in that first picture
Virginia Rocks!
Well, you have met the Dorki crowd!
