what pressure relief piston for bypass?
Hi folks,
about to order my stuff to put my case back together but can't find the specific part numbers for the pressure relief piston ... i had my case machined, for the oil bypass the rebuild book only tells you the partnumber for the cap , not for the spring and pistons itself 999.064.026.02 for the cap can somebody tell me what other thingies i need for proper operation of the pressure relief system with the oil bypass drilled? the book mentions an update kit , but can't find it on the pelican site? |
Stijn,
You need the parts listed below (two pistons, one spring, one sleeve and two plugs. http://forums.pelicanparts.com/uploa...1103027589.jpg |
Thanks Peter,
so i need the following 911.107.512.00 Piston Pressure Relief Valve 1 930.107.531.01 Spring new 86 mm 1 930.107.533.00 Spring guide 1 999.064.016.02 Plug new with groove 2 900.123.071.30 Gasket 2 901.107.531.00 Spring Safety Valve 1 added those to my project list , going to ordere this week , might get my short block assembled and closed before the end of this year :D |
911.107.512.00 Piston Pressure Relief Valve 2
als jij voor het bier zorgt, wil ik je wel helpen dichtmaken |
lol
'kzal nog wel iets laten horen als ik zo ongeveer alles klaar heb je begrijpt wel , dat er enkel belgische heavy in mijne frigo te vinden is? |
das prima, liever geen laf bier
I just looked it up yesterday. It's:
pel rebkt oil1 $31.45 |
Thx Bk
that kit is about 10 bucks cheaper than the seperate components in it you saved me 10 bucks , if you ever visit Rotterdam : let me know and i'll introduce you to some fine Belgian beers and a monster hangover :D LOL > this thread is turning into a beer promise thread |
These part numbers are also listed on Page 215 of the book, in Appendix B.
-Wayne |
| All times are GMT -8. The time now is 11:46 PM. |
