ot 356 engine rebuild
I am helping my dad do atop end on his 356 sc. Has anybody ever been into one of those before?? I have rebuilt several 911 engines and now the difference between cylinder coatings etc. Anybody know what coating I am dealing with on this 64 model?? Any hints on this would be good.
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 12-16-2004, 04:40 AM
jluetjen's Avatar
Did you ask the Pelican 356 board?
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 12-16-2004, 04:45 AM
Nothing seems to happen over there
Ben
89 944,85.5 944
914-6werkshop.com
Old 12-16-2004, 05:07 AM
abit off center
cgarr's Avatar
I rebuilt my 69 912 engine which is much the same. are you doing the heads yourself or sending them out? The cylinders, on my 912 were alum with steel inserts, and known to crack often, no coating, a good replacement are solid steel cylinders 83 or 86mm and J&E pistons, The engine is a lot like working on the old VW's in some aspects.
Craig
______________________
Craig
G2Performance
Old 12-16-2004, 08:27 AM
My dads cylinders are all aluminum look much like a 911
Ben
89 944,85.5 944
914-6werkshop.com
Old 12-16-2004, 09:12 AM
are they the original 82.5mm bore Mahle cylinders. These have aluminium cooling fins and a steel insert like cgarr said. I believe the 356sc engine is the same as the 912 engine. Do you have the aliminium rocker assemblies?(these are unique to the sc's i believe). Your heads can be rebuilt by:
competition engineering
http://competitioneng.com/
or 356 Enterpsises
http://356enterprises.com/
both are top notch and i believe that 356 is in michigan and the other is in california.
You could also probably do much of the head work yourself. Springs, shims, valve retainers and keepers, and valve guides should all be replaced. Valves could be replaced if they appear worn, be sure to get the soduim filled exhaust valves. And check for cracks in the combustion chamber around the spark plug hole as this is an area where cracks commonly develop. The rocker arms and assmembly could probably be reused, just check for excessive wear or pitting on the rocker faces.
Old 12-16-2004, 09:51 AM
abit off center
cgarr's Avatar
He must have the twin cam carrera engine then, be carefull they are xtra rare, hard to find and worth thousands,
Craig
Craig
G2Performance
Old 12-16-2004, 09:52 AM
No it is not a carrera engine. it does not have steel inserts and they are mahle pistons. I am going to measure them up next week when I have more time. Heads are being locally (me) Sodiums for sure and it is a numbers matching 64 sc
Ben
89 944,85.5 944
914-6werkshop.com
Old 12-16-2004, 10:10 AM
Here we go I had a few minutes and took some pics any help would be great
Ben
89 944,85.5 944
914-6werkshop.com
Old 12-16-2004, 06:57 PM
Thanks wayne I will try to find them.
Ben
89 944,85.5 944
914-6werkshop.com
Old 12-17-2004, 06:28 AM
stevepaa's Avatar
http://www.hcpresearch.com/
Harry is no longer with us, but his knowledge lives on.
steve
old rocket inguneer
Old 12-23-2004, 01:28 PM
found out that I have standard sc cylinders and I have aftermarket MC pistons. They don't measure out to well so My dad is ordering a big bore kit today! I wonder if I could have these cylinders recoated to size??
Ben
89 944,85.5 944
914-6werkshop.com
Old 12-24-2004, 07:21 AM
