H.G.P.'s Avatar
Question OUTER intermediate shaft bearing, hole or no hole?
My old outer intermediate shaft bearing has a hole in it's center, the replacement 996-101-137-80 does not. Should one be machined into the new.
Thanks!!!!
1969 911 E Coupe
"Little Bull" "Horse"
"H." Heart, "G." Gears, and "P" the Porsche
Old 12-21-2004, 11:57 AM
Author of "101 Projects"
Wayne 962's Avatar
Cases varied over the years. The rule of thumb is that if there is a hole in the case where the hole in the bearing should be, then there needs to be a hole in the bearing. Inner and outer intermediate shaft bearings are different too, with respect to needing the holes...
-Wayne
Old 12-21-2004, 12:18 PM
H.G.P.'s Avatar
-Wayne
This is the outer bearing.....there is no hole in the case. There is a hole in the intermediate shaft itself, forward of the sprockets.
1969 911 E Coupe
Old 12-21-2004, 03:44 PM
