Piston replacement
My recently purchased 1968 911T 2.0 is in the local (French) Porsche garage having a complete inspection. The mechanic has advised that one of the pistons needs replacing but is having difficulties sourcing a manufacturer (apparantly this is no longer available from Porsche).
Can you advise a manufacturer who makes this component? Or, if it's possible to instead use a good condition used Piston (and just replace just the faulty one, not the whole set)? Thanks in advance for any help. |
Author of "101 Projects"
Yes, you can replace a single piston, however, if one is worn out or has seen damage, then the others are not likely to be in spec either.
These engines, while not necessarily high performance (only rated at 110 HP by Porsche) really do seem to last forever. There should be plenty of used T pistons that will suit your purpose - check the classifieds... Almost the same engine as the 914-6 too, if that helps... -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Thanks Wayne,
I will keep looking.
1968 911 |
Try Tom Woodford at 1-760-731-7535...
-Wayne
