Virginia Rocks!
VaSteve's Avatar
What is the fix for this? (photo)
In taking off the fan shroud on the left (driver's) side, I snapped off two of the bolts. After drilling them out and using one of those reversing bits, I was able to get all of the bolt out. It appears that I damaged the threads. What is the fix for this? Can I just run a tap and die set over it to rethread the hole and use the same size bolt? These bolts only hold down the shroud so it's not really carrying a load or any vital parts (like the ones that hold on the throttle linkage).
I am not completely disassembling the engine so I'm avoiding taking the heads off and to the machine show for this alone.
Thanks!
(Sorry the photo kinda sucks)
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 12-29-2004, 07:53 PM
addictionMS's Avatar
I would think you are ok, I have a few of those bolts missing and I have not suffered any, if in doubt, you can always timesert it, but I think that would be overkill....
Jim
Jim Hamilton
If everything seems under control, your not going fast enough.
Old 12-29-2004, 09:04 PM
fancytown
As you said, you're just holding the shroud down. Just do as you are thinking (or as Bietendorf suggested to take it a step further), and check it periodically. This isn't a critical fastener. You should be fine...just check it after a few runs.
all cars sold.
Old 12-30-2004, 12:00 PM
Party Member
viejopatron's Avatar
When I buggered some M10 threads, I got a repair kit from McMaster-Carr. The kit includes a drill bit, tap, insert installer and inserts. Go online to the M-C site and enter "Thread repair" in the search field.
http://www.mcmaster.com/
Gary
71 911T Miss Demeanor / 2013 Audi Q5 Hundeführer / 1995 993 Miss Adventure
Old 12-30-2004, 05:08 PM
Virginia Rocks!
VaSteve's Avatar
Just to wrap up. I got lucky, I was able to chase the threads with a tap kit. There were enough threads left at the bottom to hold in the bolt. Thankfully, it was only a shroud bolt.
Old 12-30-2004, 05:33 PM
