Send a message via Yahoo to Groovy911SC
Pilot bearing for early SC crank
For my re-build of my 1980 911 SC 3.0 engine, I sourced a standard/standard crank. The original crank was damaged. The new (to me ) crank was an early SC crank which uses a different type of pilot bearing. This bearing does not have the three screw holes in the mating surface. I am confused as to how I am going to attach the bearing to the crank before I put the clutch on the flywheel. From what I can tell, once I place the clutch on the flywheel, there will be no way to secure the bearing in place mahing alignment of the clutch impossible.
Does anyone have any experience with these older SC cranks and pilot bearings?
Any help will be appreciated! I an trying to get my engine in the car over the weekend and I am hoping I will not have to wait!
Thanks again and Happy New Year!
Old 12-31-2004, 01:24 PM
I am my 911's PO
'78 SC's Avatar
Groovy,
As described near the end of this thread there are different crank/flywheel pairings. In -79 the pilot is pressed into the flywheel (small opening); in 80+ the pilot is bolted into the end of the crank (and shows through a larger opening in the flywheel). Wayne's engine book has very good pictures of the earlier configuration; the 101 Projects book has photos of the later one.
Sorry to add to your hangover, but it appears you need a different flywheel. Hopefully one of the old pros here (I'm old, but not a pro) will chime in and maybe offer an alternative.
Happy New Year.
1978 SC - original owner
1983 SC - D stock "rescue" track car
DECEASED 2015 Cayenne Diesel (rear ended by distracted driver)
2017 Macan (happy wife...)
2016 Cayenne Turbo - tow vehicle and daily drive
Old 01-01-2005, 06:41 AM
you will need the early flywheel and pilot bearing.
206 637 4071
Old 01-01-2005, 09:45 AM
CRAP!
Thanks for the info guys!
1980 911SC
One day will be "G" Stock PCA racer
Old 01-01-2005, 12:45 PM
once i saw a late flywheel used on an early crank. the pilot bearing housing was tig welded to the flywheel. a bit odd, but seemed to work fine. i would tig it when the flywheel was bolted to the crank, so the bearing was not too far in or out. the needle bearing itself could still be replaced.
206 637 4071
Old 01-01-2005, 02:43 PM
