-   -   Inner Sprockets / Adjustment Flange (http://forums.pelicanparts.com/911-engine-rebuilding-forum/200201-inner-sprockets-adjustment-flange.html)
cassidyp 01-06-2005 08:05 AM
Same post as on used parts Forum. Looking for one inner sprocket or Adjustment Flange. I have seen them identified both ways. For a 72 911 T engine
afterburn 549 01-06-2005 08:25 AM
inners??like timing chain?? can be bought new ...Flange?? do not understand...need more info
Wayne 962 01-09-2005 01:32 AM
These parts are in our engine sections of our catalog:
http://www.pelicanparts.com/catalog/shopcart/911M_catalog.htm
-Wayne
cassidyp 01-10-2005 08:16 AM
Wayne,
Excuse my newbie ignorance, but I really am having one heck of a time understanding this cam timing process. I also have broken two teeth off of the inner sprockets while trying to get the left side timed.
( bear in mind that I have never rebuilt an engine before) Appreciate any assistance.
afterburn 549 01-10-2005 10:44 AM
cassidyp,
mabe you could say how you did that as it should not take that much force to turn the cam(s) unless your up against a piston......
350HP930 01-11-2005 07:59 PM
Something is seriously wrong if you are somehow breaking teeth off of your timing gears.
Wayne 962 01-11-2005 10:15 PM
Originally posted by cassidyp
Wayne,
I'm not sure I could break the teeth even if I tried. Silly question, but do you have a copy of the Engine Rebuild book?
-Wayne
