-   -   Gasket set/kit, oil pressure sending unit washers, how many are included if any? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/200855-gasket-set-kit-oil-pressure-sending-unit-washers-how-many-included-if-any.html)
H.G.P. 01-10-2005 02:10 PM
With my pressure sending unit (the one back by the thermostat and crankcase breather cover), I have two washers. One is copper, and the other is silver colored. (both go one the unit when operating)
I have these same washers in the large gasket kit I have. The kit has two copper washers and two silvers.
Are these copper "in the kit" ones used any place else besides the pressure sender? I do not want to use a washer that will be needed elsewhere later.
Wayne 962 01-11-2005 10:34 PM
There's a variety of them in the kits. Basically, if it fits, then use it. You can always buy another one for $.50 if you need it.
The pressure sender unit should use one washer between the adapter and the case. The sending unit itself should be installed like a pipe fitting. I usually put a light wrap of Teflon tape in there, making sure not to have any excess get into the main oil area...
-Wayne
H.G.P. 01-11-2005 10:38 PM
OK, thanks........(my kit came with two same size copper washers)
