LinkBack | Thread Tools | Rate Thread |
Gasket set/kit, oil pressure sending unit washers, how many are included if any?
With my pressure sending unit (the one back by the thermostat and crankcase breather cover), I have two washers. One is copper, and the other is silver colored. (both go one the unit when operating)
I have these same washers in the large gasket kit I have. The kit has two copper washers and two silvers. Are these copper "in the kit" ones used any place else besides the pressure sender? I do not want to use a washer that will be needed elsewhere later. Thanks
1969 911 E Coupe "Little Bull" "Horse" "H." Heart, "G." Gears, and "P" the Porsche |
Author of "101 Projects"
There's a variety of them in the kits. Basically, if it fits, then use it. You can always buy another one for $.50 if you need it.
The pressure sender unit should use one washer between the adapter and the case. The sending unit itself should be installed like a pipe fitting. I usually put a light wrap of Teflon tape in there, making sure not to have any excess get into the main oil area... -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
OK, thanks........(my kit came with two same size copper washers)
