Any point to jetting the Zeniths on a stock 2.2l?
1974 911s "It smelled like German heaven" http://www.youtube.com/watch?v=6ySt9SeZl9s |
Why? Has anything changed in the configuration? Are there any issues?
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman |
they came on the 2.2s, so the jets should be fine, other than the idle jet, which should be enlarged to 0.55, if it's smaller. this hlps to get rid of popping and greatly improves cold running and warmed up acceleration below 2500RPM. mixture screw readjustment required.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 01-12-2005 at 11:03 PM.. |
THANKS GUYS
Sorry to hijack the post but will the Zeniths work OK on a 69 911T 2.0 that was originally fitted with Webers? WIll I need to rejet them?
Thanks, Kevin |
Yorkie, I ran them on a 2.0E for awhile, everything was fine just a tad rich. I leaned out the idle ever so slightly to compensate a little. I'm now running those same carbs (with 38mm venturis installed) on my 3.0SC motor.
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com 1966 912 converted to 3.0 and IROC body SOLD unfortunately ![]() 1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity! |
