austin552's Avatar
Question Zenith Jetting
Any point to jetting the Zeniths on a stock 2.2l?
1974 911s
Old 01-12-2005, 07:44 AM
jluetjen's Avatar
Why? Has anything changed in the configuration? Are there any issues?
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 01-12-2005, 08:28 AM
they came on the 2.2s, so the jets should be fine, other than the idle jet, which should be enlarged to 0.55, if it's smaller. this hlps to get rid of popping and greatly improves cold running and warmed up acceleration below 2500RPM. mixture screw readjustment required.
206 637 4071
Old 01-12-2005, 06:59 PM
austin552's Avatar
Talking
THANKS GUYS
1974 911s
Old 01-12-2005, 10:54 PM
Sorry to hijack the post but will the Zeniths work OK on a 69 911T 2.0 that was originally fitted with Webers? WIll I need to rejet them?
Thanks,
Kevin
Old 01-13-2005, 07:56 AM
A Quiet Boom's Avatar
Yorkie, I ran them on a 2.0E for awhile, everything was fine just a tad rich. I leaned out the idle ever so slightly to compensate a little. I'm now running those same carbs (with 38mm venturis installed) on my 3.0SC motor.
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com
1966 912 converted to 3.0 and IROC body SOLD unfortunately
1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity!
Old 01-16-2005, 10:56 PM
