Alan.UK's Avatar
98mm J&Es and S cams
Hi all,
Can anyone tell me or confirm that the J&E 98mm 9.5:1 CR pistons have deep enough pockets to clear S cams?
Thanks in advance
Alan.uk
Old 01-19-2005, 01:23 PM
Call don at EBS he will tell you yes.
Old 01-19-2005, 05:45 PM
Alan.UK's Avatar
Thanks.
I will call him later today. If its yes as you say then its probably easier for me to sell my max moritz set up and buy the J&Es.
Cheers
Alan.uk
Old 01-20-2005, 03:51 AM
Alan.UK's Avatar
Yeap, I am told the 98mm J&Es will work with S cams.
Looks like I may be selling the 98 MMs I have.
Alan.UK
Always learning
Old 01-20-2005, 10:40 AM
Licensed User
Shuie's Avatar
Originally posted by Alan.UK
...its probably easier for me to sell my max moritz set up....
good luck. I lowered mine to less than the cost of a set of J&Es and nobody would buy them. You may want to check into having them machined for clearance with the cams.
Old 01-20-2005, 08:23 PM
Zombie
Well, if you buy J&Es, the pistonsa are new and you get piston rings too. They worth of about $250.
How much new J&Es are ??
Timo
914-6
Old 01-21-2005, 03:03 AM
You can figure something around $150 per hole with the JEs, although this price is highly dependant on the rings used, since i've seen fluctuations in ring prices such that you are up towards $180 a hole.
Charles Navarro
LN Engineering
http://www.LNengineering.com
Aircooled Precision Performance
Charles Navarro
President, LN Engineering and Bilt Racing Service
Home of Nickies, IMS Retrofit, and IMS Solution
Old 01-21-2005, 05:28 AM
Hey Alan UK,
I may be intrested in your max mortiz setup
Let me know
Old 01-21-2005, 09:48 PM
