Need opinions re: rockers
I have these 9 rockers, early forged style.
Which ones can be used? I am rather naive regarding this, so please let me know your thoughts. Polishable? useable, tossable?
one question,
why use the forged rockers since porsche redisigned them to be the weak link in the valvetrain?
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
I wish I knew.
They are technically not for me, but I am curious as to their health. Can these be polished/ re-hardened/machined? I know they should go in a HIGH-power engine. |
Come on, no one wants to give an opinion?
Licensed User
Are they from anything exotic?
My situation is probably not similar to yours, but I was told by my machinist to just buy new rockers. If you get them resurfaced, make sure the machinist has the correct fixture. Last edited by Shuie; 12-10-2004 at 01:48 PM.. |
My vote is for "tossable".
Most are worn, a few scuffed. Some early rockers had the radius pad chrome plated. These rockers are not rebuilable at a reasonable cost.
John Dougherty Dougherty Racing Cams |
Hilbilly Deluxe
Sorry for the hijack, but are used rockers worth anything? I replaced mine when I rebuilt my engine, and still have the full set (115K mile) in the garage somewhere.
Tom |
Hey Tom, I will buy them for $20
Author of "101 Projects"
Forged = Bad. Porsche designed the later rockers to be "breakable" upon impact to protect the rest of the valvetrain. They found the forged rockers were too strong, and if piston / valve impact occurred, they resulted in bent valves...
Toss the forged ones, and buy new cast ones... -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Try not, Do or Do not
If your concern is survival after valve/ piston impact, perhaps greater valve to piston clearance, ty retainers, Supertec valve springs or a simple rev limiter make better sense. Racing engines encounter extreme conditions requiring better parts but if the parts are better for racing they are quite often better for every day use. BTW: If you have valve to piston contact that does not bend the valve you must still replace the valve or risk the probability of the valve breaking during ordinary use. If you are planning on throwing early forged rockers away please throw them in my direction. .
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 01-14-2005 at 09:05 AM.. |
A reason why they are cast ...
![]() and another ... ![]() Overrev on a 2.0L race motor we run. Replaced, drove around the paddock, did a leak down and #s were marginal (besides dmage to valves) ... called it a weekend. Jason |
With proper valve to piston clearance and SUPERTEC valve springs, there is a good possibilty that you would not have needed breakaway rockers.
BTW: we have seen cast rockers break on over rev with absolutely no valve contact. At first we thought coil bind, but after inspection we determined that the cause was just stress.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 01-14-2005 at 09:20 AM.. |
Especially on BIG overrevs. (Telltale tack and reset is out of the driver's reach.)We had "special" valves in there and some other tricks. Won't get into details as several of our competitors are on this board .Ever get a measurement on how much force it takes to brake the forged ones versus the cast ones? Just curious. Jason |
Banned
I would suggest going to a Porsche machine shop like Ollies and ask them what they think and how much to resurface.
I strongly suspect that they would recommend resurfacing and using what you have. PS if you don't want to send them to Henry, please send them to me. Last edited by snowman; 01-16-2005 at 10:36 PM.. |
Banned
I supprt Henry's assesment.,cheers,Antonio.
