LinkBack | Thread Tools | Rate Thread |
1969 E Mahles, Pistons in cylinders on bench, or pistons on rods first?
A. Haynes shows heating pistons in boiling water, placing them on rods first,...... but I'd rather ........
B...... put the pistons in the cylinders on the workbench first as Wayne states. Will I run into obstacles with either choice for a 1969 E with Mahle E pistons? (I can't see how I can compress the rings safely if the pistons are on the rods first )Also: (Is there a page in Wayne's book regarding installation of the "left" circlips?) Thanks
1969 911 E Coupe "Little Bull" "Horse" "H." Heart, "G." Gears, and "P" the Porsche |
I have found it easier to put the pistons in the cylinders first. Works better for me. Lots of folks do it the other way though. Never heard of boiling the pistons.
Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Warren Hall Student
I use the piston in cylinder first technic. It seems less frustrating.
When I go to install the P+C's I just install them in place with the rod lined up with the piston wrist pin hole. Then I heat the crown of the piston with a propane torch and gently tap the pin in.
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
Irrationally exuberant
I 2nd what Jeff said. I've done it both ways and I prefer the control of putting the pistons in the cylinders on the bench.
I leave the wrist pins (in number bags) in the freezer the night before and I test the wrist pin fit on the bench just in case. If you raise a burr when you remove the wrist pin clips (easy to do) the pin won't want to go in. Better to find out on the bench than when you're trying to fit it to the rod. -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
1969 911 E Coupe "Little Bull" "Horse" "H." Heart, "G." Gears, and "P" the Porsche Last edited by H.G.P.; 01-13-2005 at 09:08 PM.. |
