Insane Dutchman
Will a 74.4 mm crank fit in a 3.0 case
Getting my act together on my Carrera reconstruction. 6 speed transmission is on the way, am now worrying about flywheels....
Which brings me to crankshafts. Intention is to build a 3.4 litre using 98 mm pistons and cylinders with a 74.4 mm crankshaft, using my 930/03 3.0 litre European case.
Any problems with fitting the later crankshaft into the 930/03 case? I assume it is a drop in....
BTW, any good deals on a std/std 74.4 mm crank? I was thinking of going to Porsche and getting a new one
Dennis
1975 911S with Kremer 3.2
1989 911 Carrera Project Car
Old 01-17-2005, 08:41 AM
Irrationally exuberant
ChrisBennet's Avatar
Sorry, I don't know if one will fit. I'd think it would.
Even used 3.2 cranks are really expensive when you can find them. They go for something like $1100-1400 for a STD/STD. A 930 crank is supposed to be the same as a 3.2 and it already has the right distributor drive on the crank if you intend to use your CCW turning SC distributor. Someone (FredC?) was selling a 930 crank and rods in the classifieds at a very reasonable price not long ago.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 01-17-2005, 09:04 AM
