Kolibri
blackbird225's Avatar
Teardown Day one: That's why it leaked
I tore into my first 911 engine today. Saving all hardware int baggies, and following wayne's book.
I started to take the 4,5,6 cam tower off and that's when I found what you are NOT supposed to do. Scribe the cylinder number with huge numbers into the mating surface.
and then AGAIN on the cam tower...
Amazing my car didn't leak gallons onto the street with that black stuff on there in a big bead.
This is where my insane ticking came from. A fried rokcer and cam lobe from a blocked squirter...
And lastly... Here is what an impact wrench can do to an adjusting flange.. Don't try this at home
More later of course...
Michael
1942 VW Kübelwagen
1940 Zündapp KS 600
1941 Zündapp KS 750
1975 Volvo C303 TGBII
1967 Honda S90, 1975 CB550
Old 01-31-2005, 05:23 PM
Michael,
If you happen to need cam towers cams, or cam hardware for 1969T, I just happen to have a set. I disassembled a 69T years ago and still have that stuff in my attic. And I promise the cam towers weren't scribed like yours...
They're yours for a very reasonable price. Send me a PM.
Old 01-31-2005, 05:52 PM
dtw dtw is offline
GAFB
Ditto here Michael, if Rob doesn't have what you need.
That cam nut!! Wow.
Several BMWs
Old 01-31-2005, 08:21 PM
Banned
snowman's Avatar
Try JB weld on the cam nut, save a couple cents.
Old 01-31-2005, 10:51 PM
Kolibri
I forgot to tell you how that cam nut got liek that. After heating, liquid wrenching, correct tools, breaker bar, etc etc, I had to DRILL it in half to get it off the cam. IT was deformed around the cam somehow. After I even the split the cam nut it required a drift to knock the half piece off!
No, the butane torch did not weld it on. The funny ting is, that the liquid wrench had penetrated all the way through all of the threads. The po had just put so much torque on there. It must have been like 150lbs or more. Unreal. BK911 saw it with his own eyes.
michael
1942 VW Kübelwagen
1940 Zündapp KS 600
1941 Zündapp KS 750
Old 02-01-2005, 04:59 AM
