-   -   964/993 Longblock Strenghts-Weaknesses? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/203663-964-993-longblock-strenghts-weaknesses.html)
wheatdog 01-28-2005 03:38 PM
Still looking to build a hotrod 3.6. Which lower end (crank/rods) is recommended and why. I've heard 993 rods may be a weak point. True/false? The 964's lighter crank requires a harmonic balancer. Is this a problem? I can buy a 964 cheaper and apply savings to ITB injection, cams etc. Recommendations, opinions?
wheatdog
Porschekid962 01-30-2005 01:34 AM
http://www.9mracing.co.uk/html/modules.php?op=modload&name=NinemeisterContent&fil e=index&req=viewarticle&articleid=9&topic=4&articl ename=3.8%20Litre%20Racing%20Engine%20Build
check that out, build up of a 3.8, the pieces that were used and why. I am sure some would argue for other parts but its a nice starting point. Have you called up any of the reputable engine builders that are often mentioned here? I would call Henry Schmidt (supertecperformance.com), Steve Weiner (rennsportsystems.com) and Jerry woods to see what they have to see. I think the weak part in the 993 rods are the bolts but not the rods themselves. You can always bolt 964 rods onto a 993 crank cant you?
Why not just take either 3.6 mill, put in some hotter cams, higher CR pistons, top it off with ITB's and get a nice DTA or Motex ECU and have fun.
ChrisBennet 01-30-2005 05:12 AM
Sorry can't help much. I do know 993 and 964 rods are different at the small end at least. 993 pistons won't fit on 964 rods.
-Chris
wheatdog 01-31-2005 01:43 AM
"Why not just take either 3.6 mill, put in some hotter cams, higher CR pistons, top it off with ITB's and get a nice DTA or Motex ECU and have fun."
Porschekid, you are clairvoyant! That's exactly what I had in mind. One thing I have to check is whether the set up above will make much more power than a upcammed and reprogrammed Vram. If not, why blow the big $$$. I'll call Schmidt and Weiner to see.
Wheatdog
Bill Verburg 01-31-2005 12:17 PM
Your question was answered URL=http://forums.pelicanparts.com/showthread.php?s=&postid=1731455#post1731455]here[/URL]
The vrams also have bigger ports and valves
All of this is moot if going w/ DTA or Motec as you will want even bigger valves and ports.
All in all any 993 is a better base to start from.
