-   -   2.5 or 2.6 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/203850-2-5-2-6-a.html)
Shuie 01-30-2005 07:39 AM
2.5 or 2.6
The thread blue72s started about the 2.6 performance figures has got me thinking. Here is blues thread I always like to learn about different engine configs and neither of these has been extensively documented here.
Short stroke 2.5 - 66mmx90mm
-Tyson recently built a hotrod 2.5 for Scruffy. His old posts gave a pretty good idea of what it would take to build this motor. Basically a destroked high compression 2.7 RS using 2.2 crank and rods. MFI induction, of course.
Short stroke 2.6 - 66mmx92mm
-Henry has mentioned this engine before. It basically sounds like a destroked 2.8 RSR (or a destroked version of Grady's 2.8 S) engine using the 2.2 crank and rods. I’ve never seen an actual measured CR for the 92mm Mahle RSR pistons when used with the 2.4 or 2.2 heads, but the indication in the very few old posts about this motor is that it’s going to be well over 10:1. Twin plugs would be required for pump gas, and Henry has already mentioned needing a custom distributor or a crank fired ignition.
I’m trying to weigh the positives and negatives of each engine. Obviously both of the engine would need to be built from the bearings out with case mods etc. Neither will be cheap, but nothing about these cars is. There is not a lot of documentation available for either of these engines so I’m asking for your thoughts on either here.
Main question:
Is there a big difference between the two engines?
Is there a 'best' core motor to start with if someone wanted to have one of these engines built? Would it be better to start with a 2.2 crank and rods and either a 2.4 T or a 2.7 CIS motor? Or would it be better to start with a 2.2 motor and do all the case mods. I already have a 2.7RS MFI system and a set of core stacks and throttle bodies from a '69e, so please assume MFI for the induction.
Thanks for the help!
Scott Clarke 01-31-2005 12:35 PM
Sherman-
I faced the question of which case to use for my 2.5. I started with an early 2.2E motor, but elected to buy a 7R case anyway. The cost of doing the modifications to the 2.2 easily would exceed the cost of a 2.7 7R case, so it seemed to make no sense to didle with the 2.2. This is especially true if the 2.2 case has no piston squirters (like mine). Oddly enough, my case didn't even have the second intermediate shaft bearing, although all 2.2s are supposed to be so equiped. If you had a late 2.2 it might be a little different, but it seems like for less money you end up with a stronger case if you use a 7R.
The distributor issue caught me by surprise, but sure enough, the 2.2 distrubutor is quite different from the 2.4/2.7. I was, however, able to sell my 2.2E distributor for over twice what I paid for a very nice 2.4E replacement.
-Scott
BURN-BROS 02-01-2005 03:46 PM
Sherman, start with a 7R case for all the reasons that have been mentioned in previous threads. You also have distributor selection to deal with(hint,hint,wink,wink).
But why not the 2.8? It seems that you will be missing out on h.p./torque that I'm sure you will want.
Shuie 02-01-2005 06:34 PM
I have wanted a 2.8S since reading Grady's first posts about it here. I already have a 2.4 and a RS MFI system. The kicker for me was the RSR distributor. Now that someone has solved the RSR distributor issue ;), im thinking more about Grady's 2.8S. My 2.4 has either a 4R or a 5R case(dont remember which off the top of my head), so I need to do some more homework there.
Can a 4R or 5R case be shuffle pinned or strengthened enough to run a 2.8 at 10.5:1 on the street? I know the lifecycle of a 2.8RSR motor was measured in hours. I wonder how long to expect a 2.8 street motor to last?
Plavan 02-01-2005 06:59 PM
I vote for the 2.5L. Just had my first race with my Short Stroke, 46mm PMO killer motor. The car pulls like a tractor. I actually passed four cars when the green flag waved and led a race for the first time in my life! I'm still jazzed. I pulled past a Jagermeister RSR on the pole with this motor! The little motor kept him in back for 2 full laps around Cal Speedway. I am VERY pleased with this motor. You can do a search and find the specs.
ber911 02-02-2005 01:32 AM
Did you use 90mm cylinders sleeved down to 89mm? or genuine Mahles in your 2.5?
Robert
BURN-BROS 02-02-2005 07:02 AM
Heres my list.
7R case(dont waste the money on mods to a lower revision case)
2.8
S cams or hotter
port match to your intake
that dandy mfi you got
twinplug
Longevity will be related to rpm so if you spin it to 8000 rpm for extended periods of time expect to pull things apart sooner than a normal street engine.
Don't get me wrong on a 2.5 Its a great motor, but most of the guys That I have talked to have a soft spot for the 2.8 for a reason.
I'm a nutty guy, I would build a true 2.8 rsr spec engine and run it on the street just because. The list above is from the little voice in my head that I try to repress.
Scott Clarke 02-02-2005 12:33 PM
I guess I should add why I'm doing a 2.5 and not a 2.6. I'm using reconditioned cylinders and JE pistons. While researching my motor, I came accross a thread concerning failures of 92mm cylinders between the head gasket groove and the cylinder wall. Evidently, Mahle now supplies 92mm cylinders with the groove deleted. I decided that I didn't like the risk of this kind of failure, and a Mahle P/C set was out of reach. I spoke to Jon at EBS about this, and he reported no known failures of cylinders he had modified, but I still decided better safe than sorry. So, I'd say that doing a 2.6/2.8 is best accomplished with Mahle components, whereas a 2.5/2.7 can work with JEs.
-Scott
mpdevelopment 02-02-2005 04:18 PM
One thing to think about with respect to MFI, all the street car fuel cams begin to significantly pull back the fuel curve after 6000 engine RPM even the S unit. The race injection pumps have governers with lighter(machined) weights different springs and fuel cams. An engine with hotter than S cams (GE 60, GE 80) and a stock MFI pump will either be way over rich at low-mid RPM or way lean at high RPM
blue72s 02-14-2005 10:27 AM
2.5 or 2.6
From BA's book pg 135:
The one problem with 2.5 conversion is that the pistons provided only 8.5:1 compression when installed on their 70.4mm stroke crankshaft in the 2.7 application, so when you reduce the stroke to 66mm, you reduce the compression to something slightly less than 7.0:1.
There is a conversion approach that allows us to take advantage of the reduction of compression caused by using pistons made for the 70.4mm stroke on a 66mm stroke engine. If we use the 92mm pistons and cylinders from the 2.8RSR on a 2.0 or 2.2 engine, the compression ratio will be reduced by 1.0 for a 2.2 liter engine and 1.5 for a 2.0 liter engine; this will reduce the compression to a point where these pistons are usable with the available (street) gasoline.
KobaltBlau 02-14-2005 03:26 PM
if you aren't racing (in a class limited to 2.5 or 2.6) you might as well do a 2.8. IMHO
Scott Clarke 02-15-2005 07:44 AM
Blue72-
BA's concerns about 2.6 motors are significant if you accept his position concerning pistons. If you think that JE pistons are a perfectly reaonable alternative (as I do) then all of the difficulties he describes go away.
-Scott
blue72s 02-15-2005 09:33 AM
I've not seen any concerns about 2.6 in BA's book. Which page? What are his concerns?
Scott Clarke 02-15-2005 09:52 AM
His concerns are achieving an appropriate CR with Mahle RSR pistons. It is unclear to me what he says the resulting CR is with these pistons. My comments related to BA's take on short-stroke motors in general. In particular, he indicates that a short-strole 2.5 isn't possible with a reasonable CR.
Cupcar 02-16-2005 03:50 PM
Why not use Mahle racing 89 mm and get 2466 cc with 10.3:1 CR on a 66 mm crank
Plavan 02-16-2005 05:24 PM
Mine are 89 mm (custom J&E) 10.5:1 on a 66mm crank.
I love it
Shuie 02-16-2005 08:31 PM
okay, you have my attention. tell us more.
Where do you get these Mahles and how much do they cost? Do the case spigots have to be bored out?
Plavan 02-16-2005 08:50 PM
Good luck finding the Mahles. No known sets anywhere anymore.
Thats why i went the J&E route
Cupcar 02-16-2005 09:11 PM
Andial has 89mm IMSA 2.5's in stock, my friend just bought a set yesterday.
Around $3400??, Nikasil cylinders. Deep valve pockets. 97 mm case spigots- same as 2.7.
Mahle part numbr PS89-001.
Cupcar 02-16-2005 09:18 PM
BTW, it occurrs to me tha the 89 mm Mahle kit would yield 2626 cc and around 10.98:1 compression with a long stroke crank.
ber911 02-16-2005 10:20 PM
What cylinders are you using with the 89mm J.E pistons? I am looking to go the same route but am unsure about sleeved cylinders.
Robert
blue72s 02-17-2005 08:39 AM
P+C______________89mm_______90mm________92mm
Displacement _____2466cc_______2519cc_______2634cc
Spigot____________97mm_______97mm________97mm
CR_______________10.5_________7.0__________10.5
Price____________$3400________$1800________$3400
Take your pick.
Cupcar 02-17-2005 08:52 AM
BTW Andial has a high compression 90 mm 2.7 kit that nominally is 10.3:1 as a 2.7 on 70.4 mm stroke, comes out ~9.7:1 on a 66 mm crank and 2519 cc.
Plavan 02-17-2005 08:59 AM
I was lucky and had some old 89mm cylinders re plated.
Cupcar 02-17-2005 09:03 AM
Do the 92 mm RSR pistons require a special cylinder head machining cut to use with 2.4/2.7 heads or are people lowering CR with base gaskets alone?
kenikh 02-17-2005 02:07 PM
New to the BBS, so go easy on me. :)
Just a thought on the 2.5 short stroke motor using the RS pistons. 7:1 compression seems ideal for a blown motor (This is roughly the CR of a 3.3 turbo motor). Has anyone out there ever considered/attempted super/turbocharging a 7R cased motor? You'd obviously need to sort the MFI or carbs appropriately and swap in a no overlap cam, but seems doable. This idea has always been a pipe dream of mine, although I have obviously never tried it.
KobaltBlau 02-17-2005 05:28 PM
Welcome.
Not too many have built turbo cars on a mag case, a few with 2.7 CIS cars.
one of the big advantages of RS pistons is valve clearance for big cams. you could probably build a very powerful motor if you had a racing class that allowed 2.5 + turbo. For street or something, I think you'd be better off starting with a 930 motor. most people don't run too hot of cams with a turbo anyway.
Shuie 02-17-2005 09:10 PM
Considered? Yes. Attempted? No.
A small displacement turbo is one of my dream motors. 2.5 using the low compression of the Mahle P&Cs on an aluminum case, 2.2 crank & rods, big oil pump, Supertec headstuds, Carrera manifold and motronic ECU w/knock sensor. Thats all I could figure out on my own though. Researching this stuff made my head hurt and I came to the conclusion that it was going to take someone a lot smarter than me to figure the rest of the motor specifics out.
Goran forwarded me a couple of websites on turbo charger maps, etc, in response to the link above. I'll see if I can find them.
KobaltBlau 02-17-2005 10:01 PM
Originally posted by Shuie
Attempted? No.
not quite true, there have been a few turbos on 2.7 CIS, at least one of them using that BAE(?) kit. we're not talking super high output, though. Certainly a different kind of motor than you'r describing, Shuie.
kenikh 02-18-2005 08:33 AM
I was thinking almost exactly in line w/ Shuie, except I am preferential to using a supercharger, specifically the Eaton unit out of a C230 Mercedes. It is perfectly sized for a 2.5L flat six. I have seen plenty of 3.2 installs using an Eaton roots type supercharger, integrating it with a serpentine belt running off of the crank. There is just something about not interrupting that beautiful exhaust note with a turbo...
I also agree with Shuie on another thing: the research is making my head hurt. I figure the case would have to be aluminum (but am not 100% sure), boat tailed and shuffle pinned with all Raceware or Arp hardware. Stock rods would probably be a no-no. Twin plugs, pretty much a must. Piston squirters installed if none exist. An intercooler would have to be involved. Cam would need to have minimal overlap (3.0/3.3 turbo unit?).
I also like the idea of a Carrera or 3.3 Turbo manifold, but the cost of a Motec w/ crankfire is brutal. Then again, the programability of the Motec in the long run (and the tunability a Lambda/knock sensor provide) would probably pay for itself in the labor you'd save trying to figure out all of that stuff without data acquisition. I belive that you can get the Motec brain with a boost sender, too.
My biggest question is how much of a beating can the lower end of an early motor take? If you have a 2.5L motor churning out 260-270HP, it makes no sense to build it if the bottom end goes sloppy in 20K miles.
Thoughts?
KobaltBlau 02-18-2005 09:59 AM
interesting ideas, but I stand by the assertion that starting with a 3.3 turbo motor would be cheaper and more powerful. If you have some odd-ball racing class to fit into it's a different deal.
kenikh 02-18-2005 10:08 AM
You are 100% correct on all of your points. It would absolutely be cheaper and almost assuredly be more powerful. The only advantage to the short stroke, small pistoned motor would be that it would have the potential to redline higher, which is a source of fun unto itself.
This isn't for an oddball racing class; it would be a street motor. Unfortunately, I'm just an oddball with a penchant for the unusual. Just knowing myself, I'd never be happy with a 3.0/3.3 turbo in there. Anyone can swap in a factory motor, but a one-off lump is a conversation piece that never gets old. Then again, it could become a headache that never goes away...
KobaltBlau 02-18-2005 10:53 AM
I understand, we're on the same page. you're probably talking about over $10k even if you DIY the rebuild, though.
And there is a lot of fun stuff you can do with a 3.0/3.3, or even an SC base, with custom pistons, induction, injection, exhaust.
But I understand where you are coming from.
82SC 02-18-2005 11:02 AM
i dream of a 3.0RS
3.0 longblock...swap out the pistons with high comp Mahles
throw away the CIS
have a 911S MFI system bored and rebuilt for a 3.0
Brun-Bros RSR dual dizzy
longevity with the sturdy case...displacement, there is no replacement...and a rare motor that not many people out there have
that is my plan
kenikh 02-18-2005 11:48 AM
Originally posted by 82SC
i dream of a 3.0RS
throw away the CIS
that is my plan
I did a web search on the distributor you mentioned, but didn't find anything. Any hints?
Shuie 02-18-2005 11:52 AM
yes, yes, yes, there are a a lot of fun motors we could build. The 3.0 RS with MFI would be another great one. Lets get back to NA 2.5s and 2.6s though.
The 10.3:1 90mm Mahle pistons sound real interesting. Id never heard of those before. Are they as difficult to find and as expensive as the high compression 89mm P&Cs are?
edit: just called Andial and they have a set of these on the shelf :cool:
Shuie 02-18-2005 11:54 AM
Any hints?
Here are the distributors. Very exciting project.
KobaltBlau 02-18-2005 12:44 PM
me too 82SC except I would use TWM 3003s, megasquirt, and coil packs, twin plug of course. loses some "sex appeal" but gains a few things too.
Cheers,
kenikh 02-18-2005 12:57 PM
Since we talking NA motors (sorry for co-opting the thread :) ), has anybody seen one of these mean motors? 66mm stroke, 2.8L motor (95mm cyl), 9.5 CR, twin plugs, 300HP, 8600 RPM, pump gas:
http://www.supertecperformance.com/wild-porsche-engine.phtml
Gives me shivers!
KobaltBlau 02-18-2005 01:18 PM
yes, love it. Grady Clay is a big fan of this type of configuration, he has built many.
