-   -   intermediate shaft replacement-what does it involve? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/204541-intermediate-shaft-replacement-what-does-involve.html)
adomakin 02-03-2005 02:55 PM
just cleaned up my intermediate shaft and the teeth on the ally drive gear look quite badly worn on the connecting side. im assuming that this means replacement so how do you go about removing it/replacing it?
Thanks,
Andy
P.S. anyone got a good '0' intermediate shaft drive gear for sale?
ChrisBennet 02-03-2005 03:51 PM
I've done it before. I think I just used a gear puller. You know, one of those 3 arm ones. I think I heated up the aluminum gear but I can remember.
-Chris
Eagledriver 02-03-2005 07:17 PM
I took mine to a shop to have it pulled. I put the new one on myself by heating up the sproket and putting the shaft in the freezer. Just be ready to pound the sprocket back on before the temps equalize. The gear just bolts on. Get new locking tabs. I got a new gear from EBS as well as the locking tabs.
-Andy
NevenM 02-05-2005 10:01 PM
Andy
Dont assume it means replacing, They get quite a pitted look from the chain chatter, Make up a bracket and measure the backlash, I made one from a bit of flat steel and mounted the z block onto it
It is more than likely in spec
HTH
Neven
adomakin 02-06-2005 12:46 AM
nice one Neven, ive got a photo of the gear but no software to reduce the picture size so perhaps ill try and post a pic as well
Andy
NevenM 02-06-2005 01:17 AM
Andy
Email me a pic to neven@mwk.co.nz, As I said a picture wont tell you if its in spec
N
