-   -   3.2 ARP Rod Bolt source? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/205579-3-2-arp-rod-bolt-source.html)
bigrubberjeep 02-09-2005 01:49 PM
Does anyone have them in stock?
addictionMS 02-09-2005 02:33 PM
EBS Racing is your best bet
Jim
DonE 02-09-2005 05:28 PM
Try
http://competitionwarehouseusa.com/
I got my head studs and rod bolts for about $150 and $75 (respectively) cheaper than anyone else. You'll have to check if they are in stock.
Determined 02-09-2005 09:21 PM
Competition Warehouse
I too bought mine recently from Competition Warehouse and saved money on my 3.2 rod bolts and head studs. These guys are true professionals and very helpful, not to mention fast shipping. I would like to bring to your attention, some sources specify that 3.2l require 10mm rod bolts but this is not the case. In Wayne's book it clearly points out the fact that in 1984 Porsche changed from 10mm back to 9mm, I learned this the hard way. The guys at Competition Warehouse also believe that I needed 10mm rod bolts, after my engine teardown I measured and positively identified that I needed 9mm. These guys accepted my return and quickly shipped out my new set. Good luck, I'm still in the process myself of a complete rebuild, my first ever! I love it!
Best Regards,
Alex
Asking Dumb Questions is Easier than Fixing Dumb Mistakes!
bigrubberjeep 02-10-2005 01:17 PM
Orders the rod bolts today from Competition W. $155 (not bad at all)
Nice guy too, now lest see how quick they get here.
Shuie 02-10-2005 08:15 PM
Call Jon at EBS Racing
RSupdate 02-12-2005 11:07 PM
While your in there, now's the time to install the ARP headstuds too........
New ARP rod bolts, rod bearings & headstuds....a "systems" type approach that leaves a good peace of mind.....
sammyg2 02-13-2005 08:25 AM
With a 3.2, ARP head studs are overkill.
Stock steel studs upper and lower (993) will suit you just fine and won't break the bank.
bigrubberjeep 02-13-2005 07:22 PM
True Sammy, I'm not running 400hp here, just over 200 (maybe)
