Using 95mm pc's on a 2.2T
Hi,
I have a 2.2T motor and I'd like to get a bit more HP from it. I know that it is not a great motor for this. A friend has some 95mm p&c's - could i use them to make a 2.8 and would the case withstand the HP increase? Regards |
The 95mm P&C's do not fit on the early cases. The stud spacing is too big. The largest size you can put on there is 93mm and that's really pushing it. 92 is about as big as I would want to go.
| All times are GMT -8. The time now is 09:21 PM. |
