Using 95mm pc's on a 2.2T
Hi,
I have a 2.2T motor and I'd like to get a bit more HP from it. I know that it is not a great motor for this. A friend has some 95mm p&c's - could i use them to make a 2.8 and would the case withstand the HP increase?
Regards
Old 02-15-2005, 12:24 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
The 95mm P&C's do not fit on the early cases. The stud spacing is too big. The largest size you can put on there is 93mm and that's really pushing it. 92 is about as big as I would want to go.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 02-15-2005, 05:55 AM
