Plastigage or not??????
I'm almost ready to start rebuilding the engine and one of the first things to do is assembly of the crankshaft & the crank rod's.
In Wayne's book he explains how to measure the clearances between shaft & rod with plastigage. He also mentioned that the're are sceptics on using Plastigage.
While this is my first time rebuilding a 911 engine, I was wondering what your experiences are with using Plastigage and how you guys detemined whether the clearances are sufficient.
I appreciate your help!!
Old 03-04-2005, 09:12 AM
350HP930's Avatar
I use precision instruments since I work in a machine shop but plastigage is a reasonable measurement tool that you can use to check bearing clearances.
Old 03-04-2005, 06:52 PM
vichang4's Avatar
I used Plastigage when I rebuilt my engine. Just followed all of Wayne's instructions and the clearances were just right. I also checked all six rod bearings to make sure they were all just right. I used ARP bolts so retorqueing was not a problem.
Victor Toce
2000 Boxster S w/
Tequipment exhaust
1993 Spec Miata
87 911 turbo - sold
3.4 RUF pistons and cylinders
Euro CIS head
Old 03-04-2005, 09:07 PM
Hessel
For what is worth my engine builder doesn't use plastigauge he just used a dial bore gauge on the case and rods. Plastigauge is more difficult to work with and I think the results are too variable
Neven
Old 03-04-2005, 11:30 PM
Air Medal or two
afterburn 549's Avatar
All the tools in the world are nice......but good ol plasti guage is good for a mental check.....also you sleep better at night cause you know your machine shop did it right...you have the correct bngs installed and stuff.
I remember one time I was assy. a eng almost did not ck the work....WOW I had been shipped wrong size mains (1 size loose!) so I would say I am not embaresed to use the stuff.
"Thats all got to say about that" (-Forest Gump-)
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 03-05-2005, 08:04 AM
