996 996 is offline
Rockershaft retainers
Anyone who knows where these come from and if it is possible to get new ones?
Old 03-03-2005, 01:35 PM
new one on me. why would they be needed? it's not like the shafts come out that regularly. if they do, either the torque was too little or the bore in the cam tower is worn. then what about the other side?
206 637 4071
Old 03-03-2005, 03:51 PM
Jeff Alton's Avatar
Wow, never seen that before!
Jeff
www.turn3autosport.com
Old 03-03-2005, 04:26 PM
Irrationally exuberant
ChrisBennet's Avatar
Could the motor in question be from a 996 by any chance?
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 03-03-2005, 06:07 PM
This system was used in the late 80's and early 90's for 935 and 962 Rocker Shafts due to running at slightly higher RPMs. I do not think they are currently produced, but would not be very difficult to fabricate since it is merely a cap that fits on the non threaded end.
Best regards
Old 03-03-2005, 07:08 PM
Forced Induction Junkie
WERK I's Avatar
Ok, I don't know about the rest of you, but I'm confused.
The title of this thread is 996, but the cylinder head in this photo is obviously an air-cooled version. The photo shows cam tower retaining nut that has what appears to be a retaining clip near the rocker arm cap? What type of engine is this photo relating to? I take it that this type of retention system is used because of the increased valve spring pressure may cause the rocker arm to walk over time?
TIA
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 03-04-2005, 07:11 AM
Super Moderator
cstreit's Avatar
It almost looks as if the rocker shaft is notched to accept that "spring" or "arm" that comes off it... weird stuff...
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 03-05-2005, 10:02 AM
996 996 is offline
The engine is a 3,0 RS and it has been modified to almost full RSR spec. I have not seen that solution to hold the rockershafts before and I thought that this would be the right place to ask the question. I´m doing a rebuild on the engine and one of the retainers was broken and I just wanted to hear if it was possible to buy the part from some where. It is the part with the pin that holds the cap that I´m interested in.
Old 03-05-2005, 01:01 PM
