diy83sc's Avatar
Barrel Nut Thread Diameter
10mm
Old 02-24-2005, 08:27 AM
Irrationally exuberant
ChrisBennet's Avatar
So yo must be talking about the head stud or starter barrel nuts - not the 8mm ones on the intakes (3.2's) or exhaust I take it...
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 02-25-2005, 09:41 AM
diy83sc's Avatar
Yeah. I was going to the fastner shop to get a couple pieces to double-nut when I take the head studs out. But last night, I removed the valve covers and found 4, yes 4!, studs and barrel nuts laying in the cavity. The most disappointing other than two broken on the same cylinder is that one of them looks like it broke flush with the case. When I get the heads off, I'll know how ugly this can turn out to be.
So, the starter barrel nut and the 3.0 headstud barrel nut are the same threads.
Tony
Old 02-25-2005, 10:51 AM
