126coupe's Avatar
GE 60 vs. GE 80
I am thinking about stepping my cams from GE 60 to GE 80
How much will the valve to piston clearance change?
How about deck height?
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug
1984 Mercedes 500 SEC
1991 Mercedes 420 SEL
1992 Ford F-350 Dually
28' Pace Trailer
Old 02-22-2005, 08:03 AM
Still Doin Time
asphaltgambler's Avatar
Ask John (Camgrinder) he will know and I would trust his opinion.
Old 02-22-2005, 08:31 AM
camgrinder's Avatar
The GE80 cams require about 1.2mm more room on the intake side and about 1mm more on the exhaust side. The 80 cam has added duration and a 2 degree closer lobe center than the 60 cam, both changes will put the valves closer to the pistons.
An increase in compression ratio is wise with this type of change.
John Dougherty
Dougherty Racing Cams
Old 02-22-2005, 08:37 PM
