screwed up!
I stated in my post requesting 3.3 turbo rod bolt diameter information,that Wayne's book called out 10mm rod bolt diameter and doesn't specify turbo.( I just went to Appendix A assuming the info would be there) However, if I had read further in his book I would have found that he does address 3.3 tubo rod bolt diameter(9mm) on page 82!... In fact, he advises aftermarket replacement instead of OEM and explains why. (I received the same advice from the Porsche Tech thats helping me)....... learned another lesson...READ!
KM |
Ken, I must have read through Wayne's book 3 times before I actually started my rebuild. Still missed a few things though (like forgetting to transfer the starter ring from the old pressure plate to the new!)
Oh wow, when did you figure out you didn't have a starter ring, when you hit the ignition key???
I'm going to hit the book one more time. Thanks! |
-Wayne |
Re: screwed up!
:) -Wayne |
| All times are GMT -8. The time now is 03:15 PM. |
