On the contrary, the rains are killing me and costing me a small fortune. Since my project is on a hillside, the vertical hillside cuts are colapsing faster than I can erect the retaining walls. It like building sandcastles in the middle of the surf. The last rain exposed the footings of the adjacent house next door. I fear one more rain, and sections of the homes next door will begin colapsing on my side.
While I agree that a 3.6 is probably the path of least resistance to a goal of 300hp, it still seems to me that adding $10k of mods to a nice 3.2 should able to get to 300hp also? Surely? Heads, cams, pistons, PMOs and a crank fire ignition wouldn't do it?
I'm not trying to be argumentative at all - just trying to understand why 300hp is so hard to achieve with a 3.2. Mike |
Thanks guys - these are all great suggestions.
Steve - I need to get the latest chip you sent me in my car (snow over here on the right coast, rain where you are) Maybe I will not need to do anything to my 3.2 ;-) I don't have anything against force fed 911's per say. I am not a fan of the on off nature of the power. Agreed there are ways to minimize boost but on the track it makes me feel a little sketch... I have driven a load of turbo cars - all a blast and very addictive. I must say I prefer the smooth N/A power larger engines, displacement offers over the huffers of in all forms. The M5 is the devil I tell ya... And of course last but not least... The good Dr. Timmins is just an hour's drive north for me also, which is the first place I would start my project and then customize myself from there. -Jeff |
I built a "mild" 3.2. There is a 3.6 on my engine stand now that is going to be a 3.8 if that helps you at all. Mind you my 3.2 was fairly mild. I'll bet if you ask Ralph (carrera3.5l) his bill was more than 10k. Just a guess though. My bill for the 3.6/8 will be quite a bit more as well by the time it is in the car, but I will have a 3.2 to sell to get some cash back.
Jeff |
Then, seeing as you're ripping a motor apart, you won't mind that the one you're ripping up is a smoker.........you'd be doing the heads, P&C's anyway............ |
| All times are GMT -8. The time now is 12:59 AM. |
