Advice for novice
After discovering a broken exhaust head stud during my valve adjust on my 78SC I am determined to do my own rebuild. Now you have to understand that to even think of sucha thing 3 years ago would have been laughable, I barely knew which end of a screwdriver to hold. Thanks to the Pelican forums and a patient friend, who owns a nice garage w/lift I have lost much of my fear (and perhaps sense?)
The motor has 72K miles on it, no other issues, ,1 Qt 1000 miles oil consumption, runs great. I have decided to do the rebuild next fall (drive it sanely till then). I have lurked on here for a few weeks and read Waynes book twice. Here is what I am thinking but open to advice. Top end rebuild with appropriate valve and rocker work. I think I should go ahead and crack the case and see if all is well. I plan on using the steel head studs, and probably go ahead and do both intake and exhaust. I REALLY would like to go with the short stroke 3.2 conversion but cost may be too much. Am I on the right track? Suggestions? In terms of tools I am trying to accumulate what I can over the summer and pick up some parts so the impact on budget doesn't all come in the fall. Does anyone ever part with cam nut holders or crowsfeet wrenches etc? I never seem to see them for sale but they must ber out there..or do we all get so close to our tools that we can't bear to part? Anyway wish me luck, as soon as my palms heal up from those screwdriver wounds I will get even more excited.
Richard Lane 1978 911SC 1973 "Clean" RS clone |
Try not, Do or Do not
If your engine truly has only 72 K on it I would suggest a valve job, replacing the lower head studs, replacing the chains and leaving the bottom end alone. You might even want to update to Carrera tensioners. The 911 SCs were notorious for lasting 180K so your engine has a good number of miles left in it. If you were my customer that would be my suggestion to you.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 03-07-2005 at 05:23 PM.. |
rlane. To a fellow Ketuckian, I'd listen to Henry.Dan
I have plenty of lead for my pencil... just not enough paper to write on.. 82SC with 95 993 engine 2004 Ford Powerstroke |
Thanks for the advice Henry, I wondered about the bottom end, It does have the updated tensioners. I know I should not have been suprised (given all that has been written about Dilavar studs in nearly 30 year old use) bur I was STUNNED (literally!!) when that stud fell on my thick head as I loosened #1's valve adjuster.
up-fixing der car(ma)
I plan on doing the 3.2 short-stroke deal eventually. The cost is about 350 for 3.2 cylinders, 750 for boring and replating, and about 900 for new JE pistonss. That's the cheapest way to do it. Sell your 3.0 P/C and you might be in about $1600 or so additional. Best, Scott
Licensed User
Talk to Henry about the possibility of putting it on a pallet and sending it to him. Seriously, the biggest mistake I made in my abandoned rebuild project was convincing myself that I could do everything right the first time and spread the cost out over a longer period of time for less than Henry quoted me. If I had listened to him I would be done with the car now instead of still trying to figure out what to do for an engine.
Author of "101 Projects"
Oh, and make sure you have a copy of the Engine Rebuild Book: http://www.101projects.com -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
-Wayne
Not to worry Wayne, following my usual Porsche like motto..if it is worth doing..it is worth overdoing....
I have a second copy of your book at work to keep me out of trouble
Aren't the 78SC's wonderful cars? Have fun with the rebuild and good luck.
BTW, when should the piston rings be replaced?
Stopped racing and became a drummer |
