Loctite 574 thickness
My last post showed the #8 bearing leak on my 3.0SC re-build. I was expecting to pull the cases apart today and find the source of the leak (trapped O ring).....well here's the picture!
All I can think of is the thickness of the loctite sealent.....I measured it at about 14 thousands thick. Do you think this could have caused the leak? I'm at a loss at the moment, I really would like to find the cause so I can guard against it on the next build!!! Thanks Stu |
0.014" is way too thick in my opinion.
Unless you let the sealant set up too long you might want to make sure the bore for the nose bearing is not boogered up and keeping the case from properly closing up. You should also check all the mating services for any dings and mars that may be causing this. Its a good thing you had to take it apart since thats enough slack to keep the bearing shells from properly crushing/clamping. Last edited by 350HP930; 03-06-2005 at 04:56 PM.. |
Thanks for the input John.
I did a quick search on Yahoo and didn’t come up with many places to purchase Dirko sealant. Where do you get it from? |
I've also read/heard that some people "de burr" the case sealing surfaces by using a sharp tool to cut a small chamfer on either side of the surface. Apparently, a burr or ding on the edge of a sealing surface can cause the case to stand off from the adjacent surface, potentially causing a leak. Reportedly, this small chamfer eliminates such burrs. Anyone hear of this or have a comment on whether or how to do this?
abit off center
What happened to using a #50 silk thread to seal the case? Anyone doing this yet except me?
Craig
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
i get it from IMC, but pelican may be able to get it. it's an elring product. elring makes curil T also. use sparingly, so you don't have a lot of squeeze out. i use it between heads and cam towers too. i've warned about the 574 previously, but people have called BS, saying, oh you waited too long, or used too much. waited too long, no, used too much, perhaps, but still, it's not supposed to set up without being deprived of oxygen, and you would think that the quick action of squeezing the case halves together and tightening up the nuts reasonably quickly would not give it sufficient time to set up. wierd stuff. use it at your own risk as they say.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 03-07-2005 at 07:47 PM.. |
John, So its Dirko for the case, how about Curil T between the cylinders copper gasket and case?( I think someone uses it?)
Km |
everyone finds something that works for them eventually. the copper gasket actually comes with a thin sealer on it, but i spray them with K+W coppercoat on both sides for a little extra precaution. the base gaskets seal well if the case is true. 2.7s always need the bases cut in a mill. aluminum cases are usually ok.
Now I am totally confused!! John, is DIRKO going to work to seal the case halves on my 3.6? I have used 574 in the past without trouble, but really do not want any leaks in this engine either.
Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
574 worked for me too on many engines, or at least i thought it did, because there was no obvious reason to tear any down for a #8 bearing leak, or just to see if it caked up or spread out properly. who knows, there may have been a few that had the thickness issue and just didn't leak. it took just one 930 engine and 20 hours lost time for me to throw in the towel on that stuff. britwrench suggested dirko, and i've been using it since with no leakage problems. it will work on a 3.6 just fine.
What exactly is dirko if its not a anaerobic sealant?
Slumlord
From 'a website':
Dirko, a paste-like, cold vulcanizing, elastic sealing and filling compound, gives excellent adhesion to metallic and non-metallic surfaces. Even if fissures, cracks and joint movements are present, Dirko guarantees a secure seal. It has a variety of uses as a gasket, as an addition to a gasket or as a sealant from the outside. Dirko stops oil, water and air leaks. Even parts with hairline cracks are made good again in a few minutes. Ideal for cylinder head joints, gearbox joints, sumps, bearing casings, instrument casings, waterpumps and axle tubes. Temperature Range of Dirko is from approximately -50c to approximately +180c
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater Last edited by Porsche_monkey; 03-08-2005 at 07:24 AM.. |
Irrationally exuberant
Per Henry Schmidt's recommendation I've switched over to using:
Loctite 574 for the webs around the mains Threebond 1104 (aka Yamanbond) for the case perimeter and for the cam carriers Threebond 1211 for #8 bearing and 964 cylinder to case junction (no gasket, just O-ring on these) -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Was the sealant .014 all the way around the case or just near the #8 bearing? Mine looked kind of like yours with about .010-.020 thick around the #8 bearing when the o-ring pinched. It pays to look at the seam carefully after tightening up the case. You can see that kind of gap around the #8 bearing if it's there.
-Andy
72 Carrera RS replica, Spec 911 racer |
Slumlord
You should be able to get a feeler gauge in if it's .014". I guess that would be a way to check...
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
The .014 inch gap was only around the #8 bearing.
I'm going to assemble it "dry" tonight and make sure both halves come togther tight. Thanks for your help. Stu |
Just torqued the two halves together dry with only the #8 bearing assembled......I could fit a 1.5 thou feeler into the case seem.
I guess I must have got the two halves crooked the first time around? Any comments? Thanks stu |
you can actually get a feeler blade all the way thru the halves with the mains and outer nuts all torqued up?
I only torqued the bolts either side the #8 bearing and a a couple at the other end of the case.
I could only get the feeler about half way through the seam either side of the bearing. |
