| Registered Join Date: Feb 2005 Location: netherlands
				Plastigage or not??????
			I'm almost ready to start rebuilding the engine and one of the first things to do is assembly of the crankshaft & the crank rod's. In Wayne's book he explains how to measure the clearances between shaft & rod with plastigage. He also mentioned that the're are sceptics on using Plastigage. While this is my first time rebuilding a 911 engine, I was wondering what your experiences are with using Plastigage and how you guys detemined whether the clearances are sufficient. I appreciate your help!! | ||
|  03-04-2005, 08:12 AM |
| Registered Join Date: Jun 2003 Location: St Petersburg, FL
			I use precision instruments since I work in a machine shop but plastigage is a reasonable measurement tool that you can use to check bearing clearances.
|  03-04-2005, 05:52 PM |
| Registered Join Date: May 2003
			I used Plastigage when I rebuilt my engine.  Just followed all of Wayne's instructions and the clearances were just right.  I also checked all six rod bearings to make sure they were all just right.  I used ARP bolts so retorqueing was not a problem.
				__________________ Victor Toce 2000 Boxster S w/ Tequipment exhaust 1993 Spec Miata 87 911 turbo - sold 3.4 RUF pistons and cylinders Euro CIS head | ||
|  03-04-2005, 08:07 PM |
| Registered Join Date: Aug 2003 Location: New Zealand
			Hessel For what is worth my engine builder doesn't use plastigauge he just used a dial bore gauge on the case and rods. Plastigauge is more difficult to work with and I think the results are too variable Neven | ||
|  03-04-2005, 10:30 PM |
| Air Medal or two Join Date: Jul 2003 Location: cross roads
			All the tools in the world are nice......but good ol plasti guage is good for a mental check.....also you sleep better at night cause you know your machine shop did it right...you have the correct bngs installed and stuff. I remember one time I was assy. a eng almost did not ck the work....WOW I had been shipped wrong size mains (1 size loose!) so I would say I am not embaresed to use the stuff. "Thats all got to say about that" (-Forest Gump-)
				__________________ D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between | ||
|  03-05-2005, 07:04 AM |
