-   -   VERY high engine RPM on start up (http://forums.pelicanparts.com/911-engine-rebuilding-forum/209574-very-high-engine-rpm-start-up.html)
rob76turbo 03-05-2005 02:35 PM
I have just finished a six month R&R project on my '76 930. When starting up for the first time, the engine goes to about 4K RPM. I switched off the engine right away. I have checked the throttle linkage and adjusted it, it seems to be in the right range. I am wondering what I should be looking for / at next.
Thanks in adavnce!!
Jeremy Cottrell 03-05-2005 03:18 PM
It's probably your auxiliary air regulator. The early Turbos had a faster high idle than non-Turbos. You could either adjust the existing one, or swap it out for an SC unit.
350HP930 03-05-2005 06:23 PM
It could also be a vacuum leak.
jpnovak 03-05-2005 07:21 PM
Is the butterfly tight in the throttle body? Is the hand throttle on or misadjusted?
4K seems high for sensor type problems.
rob76turbo 03-06-2005 09:23 AM
BTW, how do you adjust the hand throttle?
adomakin 03-06-2005 09:48 AM
why are you having to sell it?
Andy
rob76turbo 03-06-2005 10:08 AM
It is the throttle linkage! I detached at the link on the trany and the car started, and idled normally. So when I play with the linkage between the trany and the accel pedel, I get full motion (and visa versa from the engine). But when I join the pedel linkage and the engine linkage at the trany, there seems to be 1 to 1 1/2 inches of travel I must take out of the pedel linkage for them to connect. I also seem to have run out the adjustment too. Do you think the issue is at the hand throttle?
rob76turbo 03-06-2005 10:10 AM
The CFO says to get rid of it. I dearly love the car, but I only drive it 6-10 times per year. On the day when it pulls out of the driveway (or goes into a car hauler) I will probably shed tears.
350HP930 03-06-2005 10:33 AM
It must suck to be p-whipped. ;)
TyFenn 03-06-2005 10:41 AM
Heheheee.
adomakin 03-06-2005 12:31 PM
CFO?
Andy
rob76turbo 03-06-2005 02:12 PM
Ya'll should know...
adomakin 03-06-2005 02:31 PM
nope......is it a usa thing?
Plavan 03-08-2005 03:47 PM
CFO "Chief Financial Officer" Also know as "Wifey"
350HP930 03-08-2005 04:01 PM
I got to question the masculinity of a man who would choose a boxter over a 930 and then claim his wife made him do it. :p
Wayne 962 03-09-2005 03:41 PM
Incorrectly setting the timing (heck, it's always a guess at rebuild time) can cause the engine to race as well (too much advance). Timing the distributor right away is not necessarily a bad idea...
-Wayne
