Red face VERY high engine RPM on start up
I have just finished a six month R&R project on my '76 930. When starting up for the first time, the engine goes to about 4K RPM. I switched off the engine right away. I have checked the throttle linkage and adjusted it, it seems to be in the right range. I am wondering what I should be looking for / at next.
Thanks in adavnce!!
rob76turbo
Past Porsches: 1972 914 / 1987 944S / 1976 930 / 1987 951 / 1999 986 / 1992 968 / 2001 986 S / 2006 Cayman S
Current Porsches: 1986 951 / 2005 Cayenne
Old 03-05-2005, 01:35 PM
It's probably your auxiliary air regulator. The early Turbos had a faster high idle than non-Turbos. You could either adjust the existing one, or swap it out for an SC unit.
Old 03-05-2005, 02:18 PM
350HP930's Avatar
It could also be a vacuum leak.
Old 03-05-2005, 05:23 PM
I would rather be driving
jpnovak's Avatar
Is the butterfly tight in the throttle body? Is the hand throttle on or misadjusted?
4K seems high for sensor type problems.
Old 03-05-2005, 06:21 PM
BTW, how do you adjust the hand throttle?
rob76turbo
Old 03-06-2005, 08:23 AM
adomakin's Avatar
why are you having to sell it?
Andy
Andy
1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Old 03-06-2005, 08:48 AM
It is the throttle linkage! I detached at the link on the trany and the car started, and idled normally. So when I play with the linkage between the trany and the accel pedel, I get full motion (and visa versa from the engine). But when I join the pedel linkage and the engine linkage at the trany, there seems to be 1 to 1 1/2 inches of travel I must take out of the pedel linkage for them to connect. I also seem to have run out the adjustment too. Do you think the issue is at the hand throttle?
rob76turbo
Old 03-06-2005, 09:08 AM
The CFO says to get rid of it. I dearly love the car, but I only drive it 6-10 times per year. On the day when it pulls out of the driveway (or goes into a car hauler) I will probably shed tears.
rob76turbo
Old 03-06-2005, 09:10 AM
350HP930's Avatar
It must suck to be p-whipped.
Old 03-06-2005, 09:33 AM
TyFenn's Avatar
Heheheee.
We can share the women, we can share the wine - Jack Straw.
1970 911t w/3.0
1971 914 w/2.0
1987 300E
Old 03-06-2005, 09:41 AM
adomakin's Avatar
CFO?
Andy
Andy
Old 03-06-2005, 11:31 AM
Ya'll should know...
rob76turbo
Old 03-06-2005, 01:12 PM
adomakin's Avatar
nope......is it a usa thing?
Andy
Old 03-06-2005, 01:31 PM
Plavan's Avatar
CFO "Chief Financial Officer" Also know as "Wifey"
Chad Plavan
911ST Race Car/2.5L SS Race Motor #02
1972 911T- Numbers matching- Restoring to stock
2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold)
2016 Elan NP01 Prototype racecar- Chassis #20, #02
Old 03-08-2005, 02:47 PM
350HP930's Avatar
I got to question the masculinity of a man who would choose a boxter over a 930 and then claim his wife made him do it.
Old 03-08-2005, 03:01 PM
Author of "101 Projects"
Wayne 962's Avatar
Incorrectly setting the timing (heck, it's always a guess at rebuild time) can cause the engine to race as well (too much advance). Timing the distributor right away is not necessarily a bad idea...
-Wayne
Old 03-09-2005, 02:41 PM
