I agree with that. But i use the Car also on the street, and we have very restrictive Laws here in Switzerland, so it has to looking relatively stock.
Ohter way: i go with a 98mm P&C set, Carrera 3.2 crank and stock single plug. Loosing HP, but saving money!!
Old 03-14-2005, 04:24 AM
camgrinder's Avatar
The RSR cam might too much cam if your looking for torque. My DC60 profile with 102 lobe centers will make more torque and still run on 98 octane with 10.5-1 compression ratio.
You may have to twin plug the heads depending on the piston dome shape you have.
John Dougherty
Dougherty Racing Cams
Old 03-14-2005, 09:34 AM
KobaltBlau's Avatar
what color is the car? Off-Topic but I'm curious, is it a factory color? More pictures are always good
Thanks,
Andy
Old 03-14-2005, 09:46 AM
Andy,
Ist color code 156 Orange (Playing a bit with the sun...)
Some more pictures...
Old 03-14-2005, 12:26 PM
KobaltBlau's Avatar
Awesome car. Very nicely chosen parts.
Andy
Old 03-14-2005, 02:47 PM
drag racing the short bus
dd74's Avatar
Any photographs of the front? It's a nice car to look at.
The Terror of Tiny Town
Old 03-14-2005, 03:02 PM
Frontview
Thanks for voting it nice. Good to hear that, giving me something back for my effort (1.5 Years and at least 800 hours work)
Thomas
Old 03-14-2005, 10:23 PM
Porschekid962's Avatar
Send a message via AIM to Porschekid962 Send a message via Yahoo to Porschekid962
i wanna see the motor! 3.6 mfi sounds like fun, if it ends up being anything likes henry's 3.5 your in for a big suprise.
74 911s neverending story. two feet and a jetta for now.
Old 03-15-2005, 12:14 AM
dd74's Avatar
911 Switzerland - is this the 3.2 you now have?
Can you give us the specs on it?
Thanks.
Old 03-15-2005, 04:38 PM
Licensed User
Shuie's Avatar
wow! please give us some details on the MFI setup. throttle body, stack, and pump specs? 4 journal cams? If so, what did you do for a cam seal on the pump drive side? very nice!
Old 03-15-2005, 05:47 PM
Hi,
D'ont know much of the engine. Was buying it complete. Is a Carrera 3.2 case, SC crank, 98mm P/C, 10.5:1, single plug (2.2S dizzi) 42mm throttle body, 2.2 S pump ( 0408 126 009),stacks are custom made 43-56mm, SC heads ported 43mm in, 41mm ex., S cams, 3 Journal cam cases, factory SCRS Headers, This engine was built by an ex. factory race mechanic whow worked in the 70' on the legendary 917.. Had 308 HP on the dyno. (Bases on this engine would go to 3.4 or 3.6)
Old 03-15-2005, 11:23 PM
Elombard's Avatar
Wow I cant believe you want more. Sell the car and get a new project that one is DONE!!
That is as nice looking as a long hood gets. The Iroc duck tail. very cool!
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 03-19-2005, 08:21 PM
Any update on this? I'm researching
MFI set-ups on newer motors for a possible future build---let us know the status--love the car and motor...!
JW
looking for an MFI project
Eagan, MN (just moved from Denver, CO)
Old 02-27-2006, 08:14 AM
couldn't agree more JW. Lets where this has gotten. Let Hear about Progress!!!
p.s. Welcome to MN, I too, have an MFI addiction
'71 S track car, 2.7L & Webers forever!
Old 03-02-2006, 09:20 PM
bergporsche's Avatar
Hello Thomas,
Almost building the same engine specs like you described;
930 3.3 engine case, modified to fit the 100 mm cylinders
100 mm mahle sport piston (23mm ) & cylinders (i have the mahle part number if you want to)
930 oil pump
964 hardened crank and balanced with an RSR lightened flywheel
SC modified ed heads flowed and 45mm intake and outtake ports
Valves 49mm in, 41.5mm ex
954 SC/RS cams, lift 12.1 mm inl, 10.5 mm ex, center lube, rsr chain house covers
Titanium springs and plates
MFI Bosch pump build to 3,6 ltr specs
Slide valve throttles.
Twin RSR ignition.
B & B headers.
The Cam houses must be machined about 2.75 mm of in size because the piston hits the head when you shim out for the CR, mine is 10,8 to 1.
hope to hear from you if everything worked out well with your engine
911 3.0 RSR, white shell 911S 1974
911 2.7 Carrera 2.7 euro 1974
930 3.0 turbo 1976
Old 10-18-2006, 09:22 AM
shbop's Avatar
want to follow--
Jon
Old 10-19-2006, 11:54 AM
