304065's Avatar
2.0 Oil Ring
Why is the oil scraper ring on the bottom of the piston skirt?
Why did they move it up under the compression rings for the 2.0T?
Why such a big piston skirt? Did this change occur when the "slipper skirt" was invented?
Inquiring minds want to know.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 03-15-2005, 06:37 AM
304065's Avatar
One thing that occurs to me is that it's easier to install the cylinders with the rings at the top. With the oil ring at the bottom, the piston has to be all the way inside the cylinder, which makes it impossible to install the piston pin. With the rings at the top, you can compress all three, stick the piston partially into the cylinder, then mate the piston to the rod and slide the cylinder all the way on.
'81 R65
Old 04-05-2005, 06:41 AM
jluetjen's Avatar
I donno John. I took a look in some of my books for an explanation, and while they can explain the 2ndary vibrations of a flat-plane V8 and the theory of oil-ring cross-section design, they don't explain that. I did notice that some of the 356's had pistons like that, as did the Maserati 250 engine and other pre-60's engines. But many didn't. I've rarely seen it in "modern" engines.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 04-05-2005, 02:57 PM
304065's Avatar
Yep, it's definitely an old school concept. Here are some old MGA pistons, too.
'81 R65
Old 04-05-2005, 04:42 PM
Navin Johnson
TimT's Avatar
John I noticed this thread dropping to the nether world of this BBS. I was hoping for a moment of clarity that would enable me to explain why they had those rings down there.
alas I cannot.
Then you post a pic of 5 ring pistons...
oh the humanity
Maybe chalk it up to ****ty machine practices and manufacturing tolerances
'69 911 GT-5
'75 914 GT-3
and others
Old 04-05-2005, 06:24 PM
304065's Avatar
Here is an interesting article which cites a book produced by Mahle.
http://www.babcox.com/editorial/ar/eb40354.htm
The reduction in number of rings and their width is intended to reduce friction, a good idea. As the rings get narrower, the piston is less able to tolerate bore distortion. . . do I hear water cooling?
'81 R65
Old 04-06-2005, 06:40 PM
Super Moderator
cstreit's Avatar
Interesting article, thanks John.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 04-06-2005, 07:27 PM
304065's Avatar
356 Pistons
'81 R65
Old 04-07-2005, 05:43 AM
