rotorhead's Avatar
Hylomar Sealant
I am looking for an alternative to Curil T, and I have come across Hylomar in several forms, a Spray, a paint on liguid, a Tube of Hylomar Blue and Permatex Hylomar HPF. Can anyone comment about the best form of Hylomar. I am looking to seal the copper cylinder base gaskets, Cam Housings and Chain Housings. (I have also found a threebond supplier if that helps)
2008 BMW 320i
2006 Mercedes ML320
2004 Mercedes ML270 cdi
1998 Porsche Boxter
1988 Porsche 930 Targa (sold)
Old 03-21-2005, 06:32 PM
Bird. It's the word...
Fishcop's Avatar
Steve, I used the Hylomar Blue in the jar with the brush (but I didn't use the supplied brush - used a few high quality art brushes). I used it on the copper base seals - no problems and no leaks.
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 03-22-2005, 02:42 AM
rotorhead's Avatar
Thanks John,
I am about to reassemble the top end, as the heads are now back from the machine shop. What sealant did you use for the cam towers and chain housings?
2008 BMW 320i
2006 Mercedes ML320
1998 Porsche Boxter
Old 03-22-2005, 04:01 AM
Jeff Alton's Avatar
I have used the stuff in the tube with great results.
Jeff
www.turn3autosport.com
Old 03-22-2005, 01:10 PM
Unregistered
sammyg2's Avatar
I used the hylomar in the can on my base gaskets with no leaks (knock on wood of course).
I've been using the stuff for years on gas turbines, it was developed for rolls royce jet engines. It's limited in temperature range but works great on the bearing housings and such.
I used a loctite product on my cam towers, can't remember the number right now but it was not an RTV derivative. It's something I use in the machine industry to seal machined surfaces.
Even though I went against the grain and ignored the consensus of what should be used, my engine does not leak any oil at all and hasn't since I went through it. I probably got lucky.
Old 03-23-2005, 11:36 AM
rotorhead's Avatar
Thanks guys,
I am now intending to use the stuff in the can for the copper base gaskets and the tube of hylomar blue for the cam towers and chain housings.
2008 BMW 320i
2006 Mercedes ML320
1998 Porsche Boxter
Old 03-23-2005, 01:16 PM
PRO Motorsports
Tyson Schmidt's Avatar
Originally posted by rotorhead
Thanks guys,
Don't use it for the cam tower to head surface. Use Loctite 574 for this.
Use it wherever there is movement from heat expansion, like the cylinders base gaskets, case through-bolt o-rings, oil return tube o-rings, and chain housing to cam thrust-plate o-rings.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 03-25-2005, 08:01 AM
rotorhead's Avatar
Thanks for the timely post Tyson,
I will use Threebond 1211 for the Cam housing to Cylinder Head and Hylomar for the cylinder base gaskets.
2008 BMW 320i
2006 Mercedes ML320
1998 Porsche Boxter
Old 03-25-2005, 06:48 PM
spydr32000's Avatar
Send a message via Skype™ to spydr32000
Steve, good choice for sealing heads to cam housings, my preference for sealing every where is the THREE Bond it is a fantastic range of products
Regards Mike
Regards Mike
www.spyderautomobiles.com.au
http://spyderauto.wordpress.com
http://www.facebook.com/#!/pages/Spyder-Automobiles/311683175539345
Spyder Automobiles, maintaining the integrity, building excitement!
Old 03-27-2005, 05:05 AM
rotorhead's Avatar
I have just finished the long block and I agree. I wasn't too happy with the way the hylomar went on, it didn't spread very well. The Threebond was great easy to apply and I'm confident that I have a good seal.
I'll let you know how it goes when I start the engine in a week or so.
2008 BMW 320i
2006 Mercedes ML320
1998 Porsche Boxter
Old 03-27-2005, 06:10 AM
