6771911esses's Avatar
FS: Weber 46 IDA Bodies
Was not planning to sell these but some other induction set up popped up on the horizon.
These are bodies only. They will be cleaned prior to shipping. There is no apparent damage anywhere, i.e. jet holder hole (commonly bad), and the shaft play is not as bad as some 40 I run that still work good.
Air stacks have a little oxidation around the base. It will wire brush off but there may be some discoloration. They are definately good to use. Just want to make sure you get the proper description.
All jets, etc. are available from Pierce Manifolds, Beikert, or any Weber specialist. I may have some internal parts available. Will need to know buyer's needs (sizes).
Pictures to follow 3/23.
Serious inquiries only please.
$1850.00/ pair plus shipping from 06443 (CT).
Old 03-22-2005, 02:32 AM
