-   -   2.7RS-part1 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/212712-2-7rs-part1.html)
philippeF 03-24-2005 01:43 PM
2.7RS-part1
Hello
here are a few sots of my starting project :2.7RS rebuilding...
this is the case...
http://forums.pelicanparts.com/uploa...1111700247.jpg
the workbench
http://forums.pelicanparts.com/uploa...1111700308.jpg
another view...
http://forums.pelicanparts.com/uploa...1111700366.jpg
the stock pistons are in a very good shape...(10000kms)
http://forums.pelicanparts.com/uploa...1111700429.jpg
cylinders too, (you can see the "cross")
http://forums.pelicanparts.com/uploa...1111700480.jpg
the only problem i had is with head stud removal...(your advice to fix it ?...)
http://forums.pelicanparts.com/uploa...1111700546.jpg
the others are nice...
http://forums.pelicanparts.com/uploa...1111700589.jpg
all comments are welcomed, especially for cleaning the mag case...
Philippe
Tim Walsh 03-24-2005 01:48 PM
Is that a timecert that has ripped out? The last picture looks like it had timecerts in it, but can't be sure.
philippeF 03-24-2005 01:57 PM
Hi Tim,
:eek: you give me a doubt, i'm not sure timecert are in the case, i didn't give attention...:)
i don't think i noticed something during head stud removal
:rolleyes: ??
philippeF 03-25-2005 09:29 AM
Hello
I finally checked the threads this morning, the aren't any timecerts installed, by the way, may you tell me the diameter to drill to install them , and where to get them ?
Philippe
dtw 03-25-2005 09:52 AM
Installation of timeserts, or even better, case savers, is best done by a machine shop. They jig up the case so that the inserts are installed level and on-center, so your studs all align with the cylinders properly.
If you do decide to do it yourself, call any of the race or machine shops mentioned on this board for a source.
philippeF 03-25-2005 02:34 PM
Hello
a machine shop will do the job....
i was told the case savers were not recommended on mag cases ?
advices welcomed
best regards
Philippe
