Newbie 911T Piston Question
My apologies if this question is elementary to some of you guys but will 2.2T pistons fit a 69 2.0L T motor with no mods to the heads or case?
Thanks,
Kevin
Old 04-01-2005, 01:46 PM
I guess you mean changing the set. (Pistons & Cylinders). Pistons for a 2.0 are 80 mm and 2.2 are 84 mm.
I'm not totally sure, but I think the 2.0 heads are not compatible with 2.2 Pistons & Cylinders. The bore should be too big for the 2.0 heads.
Old 04-01-2005, 02:26 PM
